Results 1 to 21 of 21
Thread: firing order?
    beware of the HB's bullet67's Avatar
    cartersville
    Default firing order?
    single overhead non-vtec zc what is the firing order to double check?
    LAWRENCEVILLE
    Hella stock member!
    cartersville
    thanks!
    cartersville
    ok stumped, i have compression i have spark i have gas and fuel pressure and the timing is right so what the hell might be going on/
    cartersville
    new plugs, wires, dizzy, rotor, cap, fuel pressure 50, timing correct and no fuses are blown anyone? anyone? why wont this run?
    check all the connection at the ecu to see if they are loose, i have had problems like this before and it was one damn wire that was loose and not connected. any cel
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    Does it turn over at all? If not check the wires on your starter. Might be your ecu plugs like jdmalltheway said.
    cartersville
    checked them out just a few minutes ago, the ecu wires that is; this is just weird everything seems to be in order but the motor just wont catch and start. ill keep digging but if anyone comes up with something let me know asap please. could someone post a picture of the distributor diagram it should be 3-4-1-2 but where is one? yes i forgot.
    cartersville
    1-3-4-2 my bad, it does turn over very well actually it just wont catch and run.
    Oct 2011
    cartersville
    Sounds really weird man. You have gas in your car? Lol i had it happen to me with my old hatch a few months a go. I had spark, fuel and my timing was all correct and it turned out i had no gas. Idk just a thought.
    cartersville
    haha yeah man def have gas. it's weird i checked compression, fuel pressure spark everywhere from every angle, timing, injector fire. I mean the thing has new plugs wires and distributor, cap, button everything!
    SOUTHERN SPEED
    macon ga
    Is the wiring harness grounded ? If not the injectors are firing .
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Oct 2011
    cartersville
    Well i ran out of ideas lol maybe h22jones is right about the harness. You should try that.
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    Out of curiosity, what were your compression readings?
    I'm not very Honda literate, so bear with me.
    Is this an OBD2 motor? If so do you have CEL?
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
    cartersville
    been a few days but if i remember correctly... 140,150ish,180,120. not great but its not enough to keep it from running its been running no sense why it would just quit. but yes it is obd2. and yes it has a CEL light. but its not on or rather wont show that its on when not running. anyone near cartersville want to take a look at this thing?
    just to add it shows 50lbs fuel pressure.
    cartersville
    so i had a thought. lets test this theory one of the plug wires was fried and i do mean fried; the alternator was never replaced but also never gave me an issue but if that last jolt to the sytem was enough could it cause the alternator to not function well enough to cause it to not start? its a thought, seeing as everything else basically is new.
    cartersville
    narrowed down to i think possibly main relay trouble harness looks fine, what are the chances this relay could have blown due to an ark from a plug wire?
    Oct 2011
    cartersville
    Could be your main relay. Make sure your grounds are all right too.
    1989 honda civic dx 4wslude's Avatar
    at a jack in a box
    here you go this is what i go buy
    cartersville
    cool thanks, guess ill check that and the main relay. damn this things on my nerves, think ill pull the alternator to just to check.
    cartersville
    ok, well the car has decided to live still not sure what caused this mess but it works and very well so thanks for the help people.
