Thread: 90 integra ls brake problem
    lawrenceville,ga
    Default 90 integra ls brake problem
    rpm gauge goes up to almost 2k rpm and goes back to normal when i let off the brake. also brake pedal gets hard, and its hard to stop the car..
    i already try bleeding the brakes. but it keeps doing the same thing
    thanks in advanced
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    brake booster going out maybe?
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
    Senior Citizen Dylan's Avatar
    Milledgeville
    What is the idle like?
    lawrenceville,ga
    Quote Originally Posted by boostedem1 View Post
    the idle is under 1k rpm but when i hold the brake pedal it jumps to 2k rpm and the brake pedal gets hard.. also when the driving the car its hard to come to a stop
    lawrenceville,ga
    Quote Originally Posted by JDMJ View Post
    most likely that's what's causing the problem
    lawrenceville,ga
    most likely that's what's causing the problem or piston in one of the calipers is stuck
    please check you brake air line and check valve going from the booster to the intake manifold. also check the fitting on the intake manifold to make sure the fitting has not come loose or kinked. more than likely its the booster IMO. Hoope this helps sir
    lawrenceville,ga
    thanks for the help brake booster and mc are bad so i have to replace and reps to ya
