rpm gauge goes up to almost 2k rpm and goes back to normal when i let off the brake. also brake pedal gets hard, and its hard to stop the car..
i already try bleeding the brakes. but it keeps doing the same thing
thanks in advanced
thanks in advanced
What is the idle like?
please check you brake air line and check valve going from the booster to the intake manifold. also check the fitting on the intake manifold to make sure the fitting has not come loose or kinked. more than likely its the booster IMO. Hoope this helps sir
thanks for the help brake booster and mc are bad so i have to replace and reps to ya
