Results 1 to 37 of 37
Thread: DIY head light restoration!
    Jan 2011
    Default DIY head light restoration!
    Materials needed!!
    1. Wet sand paper..I use 1500
    2. Water spray bottle
    3.buffing compound
    4. 3" buffing pad and buffing pad assembly!
    ** note if u have big headlights u can use a normal buffer
    5. Drill
    first thing to do is to clean the surface.....
    **If you have never done this you may want to tape around the headlights to not scratch the paint of chip it with the buffer!...
    Second...apply water to the headlight aswell to the sand paper..
    Sand. Down the headlight untill you see it dull white and no yellow looking spots!..
    Apply buffing compound to the headlight and start buffing sideways until you start seing the results...
    Wipe it down and add a little bit of waxing compound for more protection! And now u have clean headlights lol
    Norcross
    repped
    lawrenceville,ga
    i used toothpaste to clean mine..lol
    http://www.youtube.com/watch?v=CKAshYmrExc
    Jan 2011
    New pics
    Atlanta... everywhere on i85
    1500 then 2000 works fasters sir, and good pics
    Jan 2011
    I'm used to just doing it with 1500 it works good for me....
    LAWRENCEVILLE
    Its 10$ to buy a cheap headlight restore kit at autozone That comes with a sealer. yeah rubbing compound will work for a few weeks but will turn yellow again with out the sealer.
    Hella stock member!
    DA IS THE WAY FOR ME 404Chapin703's Avatar
    Jan 2010
    Quote Originally Posted by silversol View Post
    Yeah not tru... He did mine n have turn yellow not even a bit and its been almost 2 months(1 month and 1/2 ago)
    *DA SQUAD MEMBER* #85 404CHAPIN703
    Jan 2011
    Well I just want to help other ppl out..BUT if they goin to complain let them go buy that cheap shit at autozone, that doesn't work!
    Jan 2011
    plus I did my neighbors headlights about almost 6 months ago and guess what??? They still the same way!
    Kabul, Afghanistan.. Xrated O.G.'s Avatar
    Troubleville, USA
    The Teg lights turned out great... Good job...
    The XUV !!!
    Na you don't need sealer just wet sand buff then polish like the op did, will last years
    Jan 2011
    Quote Originally Posted by Xrated O.G. View Post
    Thanx
    Quote Originally Posted by georgieboi View Post
    Yup that's right! Thanx
    barrow
    I use a very similar process at work. They like using a polish after sanding (400 then 1000 to smooth things out) but I personally like to rub, what we use as, tire shine in to get a real bright look. I know it washes off after it rains, but it just needs to be pretty for inspection. Haha.
    "Yo son, u need 2 put dat chevy on some 4s wid a lil liff maine. An den get sum candy 4 it, den you have dat sh*t lukin rite"
    lawrenceville,ga
    i see u got the 94-97 integra headlights that i sold u looking good... they were so dirty and now they look almost new good job bro
    Jan 2011
    Quote Originally Posted by Bigt8aford View Post
    Lol never heard of tire shine on headlights but sounds intersting!
    Quote Originally Posted by jdm eg6 View Post
    Yeah. Bro as soon as I got home I sand them down and cleaned them!
    Certified Gearhead draggbody's Avatar
    Jul 2009
    columbus, ga
    i have done quite a few of the buffing jobs, but this is the first time i have cleared any... these headlights were BAD!!! basically they were an experiment because if they didnt turn out, i was going to just buy new ones... both were very yellow, but one of them had an attempt at resealing, i used a razor blade to clean it off, then i used a DA sander w/ 400 grit and then wet sanded w/ 600 grit... taped up the housing and had them cleared when my front sheetmetal was painted and they look perfect!!! im talking out of the box from honda perfect... so for a little work, and one more step you can keep OEM parts on your ride...
    Jan 2011
    Quote Originally Posted by draggbody View Post
    I have done that but its just too much work... I clean the headlights my way n takes me less than 3 min!
    Nice comment I know ppl will use that too
    Newnan
    I do the same, just wet sand with 1000 grit, clean, spray clearcoat. Work perfect every time. I actually just did some on an 05 toyota tacoma that look great. It will last a long time too.
    Feb 2010
    A-town
    Quote Originally Posted by greasemunkey View Post
    So yall spray car clear coat
    Sent from my PC36100 using Tapatalk
    Though just have to add that with clear coat it will sometimes turn yellow, oxidize, and peel over time. Or at least that has happened with the customer cars that I've worked on lol. It's just extra work for me to sand off the old clear too. Usually if the oxidation is bad I start with 400>600>800>1000>1200>1500>2000>3000 in that order all wet with soapy water. Then buff with compound and polish. If it's not that bad then start with 800 grit and move up. It takes FOREVER to do, but the outcome is great and lasts for a very long time! It's like having a new headlight without the high dealership cost!
    +Reps to crazydelsol for the DIY
    i've personally gotten away with using clay bar, rubbing compound and a coat of wax.
    Aug 2009
    I did mine years ago and it still look great.
    2000 grits
    Compound
    Polish
    Wash
    Done
    Enjoy.
    Coke Can Low
    AboveAndBeyond
    I tried it? And it worked. Thanks for sharing.
    JkC|photographics
    K-Figure Fhoto's
    -05 TSX-
    -97 Integra GS-R-
    -08 Ninja ZX-6R-
    Texas
    Honestly................. I use the Kit that walmart sells for 20$ and Ive done alot of business with them. I did emminodagreats headlights, mine on a few cars, including my current S2000, and my wifes jeep, and a few other cars. ANd it looks ridiculouly good and last. And theres a money back gurantee. It takes less then an hour. YES I DID SAY WALMART, and its better then a lot of the name brand ones out there. The del sol in my sig was my best. They were JDM(real) 1 piece headlights yellow and hazy and clear peeling, got em for 50$ Look at em in Sig. I soldem for 340$. WALMART KIT FTW! It comes with everything you need.
    Jan 2011
    Lol I take less than ten min doing them my way! I have tryed those kits and didn't really like the turn out! But if it works for you I'm happy!...
    Jan 2011
    Quote Originally Posted by dc2killa View Post
    I'm happy to hear that!
    Certified Gearhead jtdb8's Avatar
    Oct 2011
    where everybody knows everybody
    there are many ways to clean your lights and methods. some more effective than others. reps to all who clean lights. i clean headights myself an as sol_james i started out with those kits you can buy at wal-mart. but now i bought a system my 3m with a air orbital sander and a buffer.
    here are a couple pics of cars i done.
    (ノಠ益ಠ)ノ smoknlegend's Avatar
    Around
    Some headlights will yellow quicker than others depending on the stage of oxidation. A trick is to use sparr urethane, mixed 50/50 with mineral spirits, then applied and left to smooth out. Hell all you have to do is wetsand the light down to new plastic, not even having to polish because it allows the urethane to sit.
    Or you can also seal the headlights after polishing with a polishing compound with a product called optimum opti-coat which adds another layer to the light (its a permanent coating as opposed to wax or sealant.)
    LAWRENCEVILLE
    Quote Originally Posted by SoLJames95 View Post
    Exactly!
    Hella stock member!
    Jan 2011
    Exactly!
    Hahahah this punk here makes me laugh!
    I'M TRYING TO HELP PPL SO THEY CAN HAVE CLEAN HEADLIGHTS AND THIS GUY IS GOING TO NEGATIVE REP ME!
    Certified Gearhead DA9_Vito's Avatar
    Dec 2009
    Forsyth,GA
    Quote Originally Posted by Crazydelsol View Post
    I'M TRYING TO HELP PPL SO THEY CAN.HAVE CLEAN HEADLIGHTS AND THIS GUY IS GOING TO NEGATIVE REP ME!
    Thats how life goes sometimes.
    Texas
    i was positive repped.
    Jan 2011
    [QUOTE=SoLJames95;39336750]i was positive repped. [/QU
    It's just punk ass silversol!
    LAWRENCEVILLE
    lol u mad bro? didnt stop you from trying to buy my welder lol!
    Hella stock member!
    Jan 2011
    Lol nahhh..... and welder new is 240 with everything includes mask etc... lol my offer still stands
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    now they are fresh,clean and shinny lol.
    Hold On Not Done Accelerating
