Page 1 of 3 123 LastLast
Results 1 to 40 of 82
Thread: Uwish h2b build thread
    SOUTHERN SPEED
    macon ga
    Default Uwish h2b build thread
    I just got done with his build so i figured i would share the build with everybody.
    H23 crank
    H23 rods (aftermarket)
    type s pistons (fly cut)
    12.1 compression
    Balance shaft removal kit.
    Stock top end for now but ready for a big cam the pistons have been cut already.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    revolution big mac's Avatar
    first of all what intake is that ive been meaning to ask him. and what does fly cutting pistons mean???
    Southern Speed
    Macon
    that intake is really weird, but dont think it will make much power.
    Fly cutting is a process where the pistons were cut using a modified valve. Very neat process.
    Custom intake tube.. and "Fly cut" is to add room in the valve releifs on the pistons so the valves do not hit.
    Little info for those interested
    Mike Jones!!! Did you balance anything? Just wonder I guess... :P
    so i cutting the pistons neccary when running this setup??
    Dec 2008
    Northside
    No fan switch.
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Certified Gearhead UWISH's Avatar
    Aug 2010
    NEAR YOU
    Looks like u changed my battery lol
    Southern Speed
    Macon
    Quote Originally Posted by big mac View Post
    Not sure with stock cams but anything bigger needs it since the piston sits further up than with a h22 crank, the valve angle changes and comes down further back.
    Quote Originally Posted by UWISH View Post
    At least it matches now.....lol!
    Southside Ridin HATCH
    That intake has been on there for years, its a replica. Cant remember of what brand
    zero 1000 power chamber intake system
    ahhhhhhhhhhhhhhhhh. okay i see. thanks for info. and idk but i like that intake
    Southern Speed
    Macon
    id be curious to see a intake test on it. I plan on running a 3.5" and reduced to a 3" at the TB to start off with then plan on testing some 4".
    looks like a decent intake
    It didnt rob to much power. When we had it. Still made the correct amount of power. Actually made more power than SOMEBODYS STOCK H2b with a Carbon Wale penis! but ehhh... Who knows....
    hahaha lol
    Southern Speed
    Macon
    the whale penis intakes suck
    yes it does man. i had one and sold it got and pieced one from orielies with a velocity stack and was bettert
    Quote Originally Posted by DarKStaR View Post
    Yup.. And not in a GOOD way.. lol
    3 Inch with A V stack is what I use to.. Never failed me.
    yup im happy with it 25 dollar intake that does better than a 200 dollar one
    Southern Speed
    Macon
    you might want something a little bigger with your new build
    Dec 2008
    Northside
    I wonder who ur referring to?
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    lol.. Yea exactly..
    Well I was speaking on all the B series I had.
    You recomend a 3.5 or 4? that seems big. I only have a 70mm throttle body/mani setup. Huge intake tube, to smaller TB?
    Quote Originally Posted by *EFilliated* View Post
    Ehh... IDK, Did you have a whale penis? never seen under your hood! haha
    You know, Your not the only person that has and H2b setup.
    Southern Speed
    Macon
    I figured he was referring to nemos stock h2b
    lol.. Yea exactly..
    From what i have seen h2b's love the bigger piping...One guy has a 4"-3.5"-3" on a stock motor running 12.1@111 , and ive seen some others making good power with at least 3.5". Im reducing mine to 3" at the TB
    Dec 2008
    Northside
    Jw
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    just put a velocity stack on throttle bodie
    Southern Speed
    Macon
    wont make much power compared to having an intake on it....
    Dec 2008
    Northside
    3inch coming out the headlight with velocity stack and call it a day period
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    lol naw just being sarcastic hahaha.
    HAHA
    SOUTHERN SPEED
    macon ga
    I see people running this setup all day without cutting the pistons . The clearences are very tight but they are there . I had a block that had 15 thousanth taken off and i didnt lnow so when i tore the motor down after a balance shaft bearing took a shit (years ago). I could see were the valves were barely hitting the piston . I have cut them every since better be safe then sorry plus i dont know how peopletreat there motor so if im building it (or my dad) were doing everything we can to make sure it last. It has our name on it .
    Bobby nothing was balanced by me and no need why do you ask ? The rods come balanced to each other . I lied we do rebalance the pistons after we cut them lol.My dad took his crank to a big time v8 builder around here that we do alot of work with to see how balanced it was from the factory even though i told him it was fine . He likes to check shit lol. The guy checked it said he would be happy to get his cranks that balanced and thats good enough for me . I dont make power to 9,000 hell i hardley ever rev my motrs past eight the balance is fine they stay togther with no problems.
    ^ Thats what I was thinking. I remember you (mike) telling me, the H23 Crank/Rods setup with the Mahle 10.5 pistons would be perfect setup! No cutting or anything needed. Damn I need 500 for the damn pistons still!!!!! Know were to get them any cheaper? Thats basically the only thing im lacking, Besides just a few small things.
    SOUTHERN SPEED
    macon ga
    i run across deals every now and then next time ill hit you up.
    SOUTHERN SPEED
    macon ga
    No fan switch.
    About 90 percent of your post are two words and pointless but they havnt been in my threads so not my problem . If you dont have anything more constructive to say besides trying to tell me that not plugging up a fan switch is a no , no to make yourself look smart then just dont post in my thread . I try to be cool with everybody man but every post you post is acting like you know everything when you call me showing your stupidity all the time . I wasnt going to call you out but stop getting on here trying to make people look stupid when you dont know shit yourself that much i can tell you and you damn sure dont know more then i do. Hell you the only person i know that had a h2b that dont know shit about h2b but hey glad you know what a fan switch is . I want say any more i think you get the point now.I hope you feel just like all the people on here that you tried to make feel stupid. Everybody on here is here to learn .As much as i know i learn shit everyday so try a little harder at learning shit instead of trying so hard to look like you know everything when we both know thats not the case.
    Not that its any of your business but that connector has a jumper in it to make the fans run all the time and was like that when i got the car so i left it like that since there is nothing wrong with it being that way .
    I used to wonder why everybody gave you such a hard time ( now i see ) go try to make somebody else look foolish .
    Certified Gearhead DA9_Vito's Avatar
    Dec 2009
    Forsyth,GA
    Good looking build mike
    I ask because you fly cut the pistons...LOL, kind of a joke.. I always check shit to be safe anyways, but wondered how the pistons would weight out since you did some cutting.. I knew the answer, or your reply, but had to ask for some of the noobs that may wonder also.. Good Stuff man!!
    SOUTHERN SPEED
    macon ga
    Oh ok ,good shit yea i balanced them after wards lol well my dad did i been busy.
    hey man i txt you from my girl phone. but you didnt answer. ill pm you
