Thread: ef with d16z6 swap
    Default ef with d16z6 swap
    i have a cel on and it's a 17 which is speed sensor. speedometer works but i can't figure to get rid of the cel, i try new ecu and it'll still pop up the same cel. any help
    Dec 2008
    Northside
    disconnect the battery for a minute
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    i try that already. i reseted and after i drove it for about 20 miles and it pop back up again.
    Have you changed the cluster or anything on the car? The VSS is in the cluster so its either a bad cluster, or a break in the wiring between the cluster and ECU. This is assuming you kept a cable-clutch trans in the car and have a cable speedo.
    GWINNETT IS GREAT!
    maybe you should learn proper grammar!
    98blackcivic your a dumbass!!!! Is that proper enough for you
    Yes I kept the cable tranny and it does have a cable speedo. I haven't try a new cluster yet and it was going to be my next step. I got a crx si cluster laying around but I'll have to do some wiring because 89 si wires is little different from 90-91 si.
