Thread: 1990 integra starting problems won't turn over
    Certified Gearhead bigbadjohn07's Avatar
    centre,al
    Question 1990 integra starting problems won't turn over
    I have a 90 integra and it has to be pushed off to start. When you push in the clutch it doesn't turn over but all the guages turn on.
    when i turn the switch it does nothing
    PLEASE HELP!!!!!
    Rome,Ga
    Check clutch sensor, ground on thermostat housing
    Ignition switch
    to test the Safety neural switch just unplug it and put a jumper wire in it, then try to start it.. Next thing would be checking the tranny ground, starter its self and fuses..
    centre,al
    Alright also when im in 2nd and 3rd the car is around 1500 to 2100 rpms but when im in 5th ith revs from 2500 to 3300 rpms does anybody know what would cause this?
    centre,al
    it was working fine stopped at the store and went to crank it and it wouldn't do anything
    so i had to push it off
    Rome,Ga
    Shifter mest up? If u drove down to rome I could take a look at your car I've own 4 or so da and db1
