I have a 90 integra and it has to be pushed off to start. When you push in the clutch it doesn't turn over but all the guages turn on.
when i turn the switch it does nothing
PLEASE HELP!!!!!
PLEASE HELP!!!!!
Check clutch sensor, ground on thermostat housing
Ignition switch
to test the Safety neural switch just unplug it and put a jumper wire in it, then try to start it.. Next thing would be checking the tranny ground, starter its self and fuses..
it was working fine stopped at the store and went to crank it and it wouldn't do anything
so i had to push it off
Alright also when im in 2nd and 3rd the car is around 1500 to 2100 rpms but when im in 5th ith revs from 2500 to 3300 rpms does anybody know what would cause this?
Shifter mest up? If u drove down to rome I could take a look at your car I've own 4 or so da and db1
