Results 1 to 5 of 5
Thread: hub centric ring/ wheel center ring
    i am a incubus driftuner240's Avatar
    Jul 2009
    ATHENS,GA SNELLVILLE,GA
    Default hub centric ring/ wheel center ring
    i was looking for some feedback about hub centric/center rings. i know there r metal and plastic rings.
    Help keep the wheel centered on the hub, helps prevent vibrations.
    need one with an inner diameter of your hub, outside diameter of the wheel bore.
    Metal last longer. Plastic are cheaper. I'm using hard plastic ones right now.
    need to know anything else?
    Jul 2009
    did it take the bounce the vibration out
    i've had both and they both work to keep the vibration down. Plastic sux b/c they deteriorate over time. The metal ones i had lasted no problems. If you plan to drive on them less than 3 yrs then plastic should work. More than 3, i would go metal.
    Jul 2009
    thanks 4 the feedback i was mainly looking 4 the difference between which is better plastic or metal? i went ahead and ordered some RAYS engineering metal centric hub ring. ill update this post when they get put the test
