Thread: wiring guru's need your help!!!!
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Default wiring guru's need your help!!!!
    Sup ia I'm at a point to where I'm tired of messing with my car cause I can't figure out the previous owners wiring incapabilities.... I have a 96 integra ls with a jumper harness to an obd1 ecu, here's my problem, I'm throwing a tdc and ckp code (I've already swapped in a new dizzy) but all of the wires that control those sensors have been rewired for some reason... I'm thinking he must of wired the shielded part wrong or something but I can't find a diagram to find out what logic ground or whatever they should be wired to.... and also some wires have been cut and left hanging for a secondary o2 and vtec pressure switch on the ecu plug..... 2 wires have been also cut on the body harness side (where the engine harness plugs into under the hood) on the 14 pin connector ... could someone help me out , show me some pics of the ecu harness or something or tell me where the shieled part of the wires should be connected to. Thanks and any info is very much appreciated!!!
    JDM as......
    93 accord cb7
    (traded)
    93 del sol eg1 (traded)
    94 integra dc4 (sold)
    96 db7 ls-t (daily)
    it sounds pretty bad , I would get another harness and BAM it will be fixed without you causing more issues .
    Nov 2009
    Bremen
    That's what I'm thinking to
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    Boostin, yo!
    Oct 2008
    covington
    it sounds to me like he tried to rewire the dizzy for obd1. when you replaced the dizzy, which one did u put on it?(obd1 or obd2).
    Dec 2008
    Northside
    this
    Quote Originally Posted by Tech5 View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Nov 2009
    Bremen
    Quote Originally Posted by Jwall2323 View Post
    Both lol
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
