Results 1 to 10 of 10
Thread: 1990 ef civic fuel system problem
    Aug 2009
    Senoia, Ga
    Default 1990 ef civic fuel system problem
    Ok so the fuel pump wouldn't come on. Replaced it and everything worked. Next day I stalled out like a noob and now the fuel pump wont come on. Replaced the relay. Tried relieving the fuel pressure to get the pump on and nothing. Help somebody please
    Relay is good? Does check engine light stay on? Do you have 12v to the pump?
    Food for thought: Its common for people to install the pump, but upon raising the tank they smash the wires up on the body, Drop the tank, un-plug the pump, then plug it in.. If it works then you shorted the wire to ground.. Meaning don't smash the wires when raising the tank back up..
    Aug 2009
    Senoia, Ga
    New and old relay are good. I checked the old relay as well. I could get to some of the wires under the fuel level indicator under back seat and they seemed ok. But my next step was to drop the tank and check all the connections like u were saying. That just takes alot of time and its my only car and I can't get off work to do it nor can I take off. Its got me stressed blah
    wires run on top of the tank, if you installed a new pump chances are you mashed the wires..
    get a test light and check for 12v at the pump also.. if no volts at pump then back track to relay to see if you have 12v there..
    1989 honda civic dx 4wslude's Avatar
    at a jack in a box
    On my hatch when I bought it the fuel pump wouldn't come on and when I dropped the tank it was the wires that goes from the connecter to the pump inside the tank one of those was burned up after I fixed that the car runs fine now going on 2 years
    Dec 2008
    Northside
    check fuse 14 i believe under the dash, one of them is linked to the Fuel pump, DESCRIPTION WILL NOT SAY ANYTHING REGARDING FUEL. if 14 isnt it, check every single fuse.
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Aug 2009
    Senoia, Ga
    Fuel pump was bad. Brand new too wtf. The ef WILL ride again by gawd
    Let me guess an Air Tec, or whatever the fuck it's called...LOL, Those autozone pumps are junk!!!
    Aug 2009
    Senoia, Ga
    It was a performance pump off ebay.
    your that far already...just go with a 255 warboro. and check all your connections and voltage
Tags for this Thread
