Results 1 to 21 of 21
Thread: 1990 honda civic hatchback help
    Aug 2009
    Senoia, Ga
    Default 1990 honda civic hatchback help
    Ok so fuel pump wouldn't come on. Replaced pump worked fine. Put it in yesterday. Today it was storming and stalled out in a rush to get out the car. Now pump wont come on and no engine light. Help
    main relay!! replace it...
    del sol? 94_teg_ls's Avatar
    Quote Originally Posted by 1civic View Post
    x2
    they can get touchy with the moisture when there on there way out
    /sig
    Quote Originally Posted by 94_teg_ls View Post
    x2
    Has nothing to do with mositure Which is spelled Moisture , but what happens after years of key on key off the solider points tend to crack . You can take them apart and re solider those contacts and be good to go . If that is the problem with his car!
    Aug 2009
    Senoia, Ga
    Relay is clicking. Sometimes when I turn it over it doesn't click and the engine light comes on. But even when the light doesn't come on the fuel pump still doesn't come on at all. Could it be anything other than the relay ?
    Quote Originally Posted by blakdeth23 View Post
    No... Replace or repair the reply!!
    North Augusta, SC
    Also, replace or repair the relay...
    Back to being stock and slow
    Scottish Scotsman's Avatar
    on the road to recovery
    Quote Originally Posted by Motivation View Post
    try changing the relay...............lol
    Quote Originally Posted by Scotsman View Post
    or just fix it damnit...
    or replace it
    Aug 2009
    Senoia, Ga
    Ok putting in relay today. Fingers xsd
    did you check your fuses?
    Quote Originally Posted by Tech5 View Post
    you got an extra vtec fuse? maybe some fluid also...
    why yes, you can get vtec fluid at any parts store.... OIL! asshole! and a vtec fuse, which would be ecu, as it shouldnt work without it.!! asshole x 2
    I'll trade you a Cat!!.. Hook me up dogg!! :P
    SOUTHERN SPEED
    macon ga
    Lol fools .
    Personaly i think it is the zing wheel bushing but thats just me . Either change the filter in it or replace all together.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Quote Originally Posted by h22 jones View Post
    zing wheel bushing
    Umm, will this make power? I am so buying!!
    Aug 2009
    Senoia, Ga
    My blinker fluid was low...
    Aug 2009
    Senoia, Ga
    Ok replaced the relay. Still nothing. Help
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    did your ecu get wet sometimes in the older cars water can find its way down there to the plugs. had a friend with a del sol that leaked when parked a certain way just dried the plugs and ecu with blow drier and it ran. also some store brand pumps just dont last long or even start right up when installed and have to go get another ive seen it happen but dont know why! also could be the muffler bearing or kanooter valve! lol jk!
    kick it
Tags for this Thread
