Results 1 to 13 of 13
Thread: No power to fuel pump?
    Oct 2008
    Default No power to fuel pump?
    Ive changed the relay ive got spark got power to everything but fuel pump
    del sol? 94_teg_ls's Avatar
    what car?
    /sig
    Oct 2008
    99 civic with b16b swap
    check your fuse
    B-Town Crunk Force
    Statesboro, GA
    Also check your ground by the thermostat.
    Southside Ridin HATCH
    Relay, Fuse, Ground, another pump... This has all been said plenty of times.
    Oct 2008
    Does the ground come from the harness?
    yes and no
    Aug 2009
    A few years back, I was trying for weeks to figure why my civic got no power to the fuel pump. Later found out the OPTIONAL fuse next to the battery was out. I replace it and fuel pump work. Try it.
    Oct 2008
    Quote Originally Posted by Austin? View Post
    What optional fuse are you reffering too?
    Oct 2008
    Quote Originally Posted by jdm>usdm View Post
    Does this ground come from the harness ive checked all my fuses bought a new relay so this ground sounds like the problem but when i pulled the motor to swap it i did unhook anything from the harness to the motor need more info on this ground
    Oct 2008
    I mean i didnt unhook anything but this is my first swap and would love for a ground to fix the problem
    Rome,Ga
    They should be ground on waterneck from harness thats the main ground
    Also check your ecu fuse under hood
    Also u might wanna jump the relay just to see if ur fuel pump is good?
