Thread: HUGE mount problem. B series in EG
    Jan 2010
    We can do business
    Default HUGE mount problem. B series in EG
    OKay you guys will need to use your imagination to picture this.
    I bought a H series hatch, took it out to put a b series in. I noticed when I put the motor in that the side (transmission side) bracket where the mount is had been cut a little and a new hole had been made. Now that I have a B series mount, it does not lign up with the hole. It is like an inch away. There is not enough bracket. IDK what to do now. I was thinking to weld 2 metal plates on each side of the bracket to serve as an extension then drill a hole and place the mount there? I am not sure how to go about this. What do you guys think.
    Rome,Ga
    Cut off the cutt mount in find a wreck car cut that mount bracket off in
    Re- weld there a guy near me that prob has that mount part for u
    del sol? 94_teg_ls's Avatar
    /sig
    Jan 2011
    yup that's the best thing to do! Just cut it and find another bracket at the junk yard and re-weld it!! Gl man
    Quote Originally Posted by terrytowe22 View Post
    Jan 2010
    We can do business
    Thank you guys so much. You saved me ahuge headache. I am buying the part 27 on honda parts now it is very very cheap and brand new. Do you guys know anyone that wouldn't charge me an arm and a leg to come to carroll county to weld it for me?
    Find mount, drill spot welds out, weld in place
    Quote Originally Posted by nelson9995 View Post
    I'm close, and only have sundays tho.. Drill the welds, remove the old one, and then prep the new mount.. I have a spot welder, but you will be on your own with prep work and re-painting tho.. Cover my gas and it's a done deal..
    pretty much very easy and if done right you will have no issues
    Jan 2010
    We can do business
    i ordered the bracket today. so I should get it soon.
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    Default priced out
    where did you order the bracket from. prices and partn umbers? i may be needing one for my automatic eg.
    Jan 2010
    We can do business
    check the link above
    by 94tegls
    96 Ls
    gaylesville al
    is yous cut i just did a auto to Manuel swap and all u half to do is get a drop mount
    50 bucks on ebay
