Thread: exhaust cam jumping teeth.
    Jan 2010
    We can do business
    Default exhaust cam jumping teeth.
    okay guys I built a gsr. With supertech valvetrain aftermarket cams and cam gears. when i set timing at 0 its all good. when I try to turn the crank (motor is still on a stand) the intake cam moves and the exhast moves some but after a bit the exhaust cam stops and when I apply moe force to the crank the intake spins and the belt jumps teeth on the exhaust cam because it didn't move. I'm so confused. It's a gsr head. What can it be?
    del sol? 94_teg_ls's Avatar
    how tight are your caps and is it a new timing belt?
    /sig
    Jan 2010
    We can do business
    brand new belt and cam caps are at 20lbs
    what timing belt are you using and which cam gears are you using too?
    Also when you install the timing belt you always back the one of the gears off a tooth to get all the slack out between the two cam gears.remember you want all the slack on the tensioner side not the water pump
    Quote Originally Posted by 94_teg_ls View Post
    cam caps wont make it jump timing just sayin
    Jan 2010
    We can do business
    okay guys I have it figured out. I was spinning to crank clockwise when its suppose to be counterclockwise. dang I feel stupid lol
    yeah that was smart I hope you got the belt tight since you don't know which way to spin the crank lol
    you got lucky can cause damage that way.
    Jan 2010
    We can do business
    lol. i hope I didnt mess anything up. is a new gates racing belt tho
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    your good 2 go if hondas weren't tuff we wouldn't have them right?
    Quote Originally Posted by turbob20 View Post
    tough lololol...I have them because my diesel drinks gas !!!
    LaFayette Ga.
    lol i hear that!
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    just mind, your oil pump only works and pumps oil in the correct direction when the motor is spinning in the correct direction, and the more you spin the motor, the more assembly lube you have for startup. i believe the rule is 1 full rotation, and everything should be together and set.
