Thread: White steam/ pressure out the valve cover breather
    Senior Member cm7k24's Avatar
    kennesaw
    Default White steam/ pressure out the valve cover breather
    noticed a steam coming out of my valve cover breather,
    still idled fine, drove fine and all.
    did a compression check and read 220 220 160 220
    could it just be a headgasket on its way out? or rings?
    btw its a stock h22a
    Wounded
    kennesaw
    what do you mean? lol
    Normally a ton of pressure out of the valve cover with a lot of white smoke could be a ringland, but is pull cover and check for moisture
    I just noticed the compression numbers, and they're not super low, so I would lean towards checking for moisture/blown headgasket etc.
    prob popped ringland or a really blown headgasket in that cylinder.
    If its headgasket you should see coolant in the oil.
    my vote is you popped a ringland
    kennesaw
    well, i guess ill have to just take the head of and look.
    i figured a ringland would have a lot lower compression than what it is at..
    someone noticed the other night that i had the over flow hose plugged with a screw.. idk why i had it like that as i was putting the car together.
    so im thinking thats what could have led to the problem with the head gasket. i never checked my oil to see if there was water or anything.
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    same thing happened to me, turnd out it was a ring landland.
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    The overflow hose won't cause a blown headgasket. It would overheat first.
    The fact there's a 60-80psi difference in that cylinder means something pretty bad is wrong. If to have excess crank case pressure coming out the valve cover, it's a cracked ringland, oil is getting by the rings
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    something piston wise x2
