Results 1 to 10 of 10
Thread: JL Audio W7 Subwoofer Enclosures - Custom Built by Hand To Specs - Killer Price
    Default JL Audio W7 Subwoofer Enclosures - Custom Built by Hand To Specs - Killer Price
    We have a deal for all the JL Audio W7 owners out there. This is a Ebay special that we are currently offering and wanted to include the local scene to take advantage of this deal. These enclosures are priced much lower than our normal custom built enclosures since we are mass producing them. Check out the features, specs, and photos blow along with the pricing. We have these built for the 8", 10", 12", and 13" models!
    Grade A MDF Wood - The enclosure is built out of Grade A 3/4" MDF Wood. This is ideal for any enclosure system no matter the amount of power being applied.
    Triple Thick Front Baffle - The enclosure is braced by a triple thick front baffle. This means it is 2.25" thick! This will ensure no matter the subwoofer used or the power being applied, this enclosure is built to handle it!
    Rounded Port Edges & 45 Degree Angles - The port edges is rounded and all corners have 45 degree angles. This allows maximum airflow for ported enclosure. NEVER buy a ported enclosure without this...you will choke your airflow!
    Recessed Subwoofer Mounting - This will allow your subwoofer to mount flush with the exterior of the enclosure. You end up with a custom, clean look that you will love!
    Routed Opening - The subwoofer opening is cut using a router...not a jigsaw like most Ebay sellers. This means it is cut perfect for the size of the subwoofer and that is is perfectly round!
    Beveled Edges - The edges on the sides of the enclosure has been beveled by a router to give you a custom, clean look that you will love!
    Gold Plated Twist Terminal Cup - This ensures you gettting maximium signal between your amp and your sub, we use a Heavy Duty Gold Plated terminal cup. The posts are twist design so you get a proper connection.
    Carpet Selection - We offer our encloures in both Charcoal (pictured) and Black. When you purchase the item, please state which color you want.
    LIFETIME WARRANTY - We offer a Lifetime Warranty on all custom built enclosures. This means if your subwoofer blows our enclosure apart...you get a BRAND NEW ONE FOR FREE!
    8" W7 Enclosure Specs ($115)
    Dimensions - 33" Width x 11" Height x 15" Depth
    Volume - 1.0 Cubic Feet After All Displacements
    Port Area - 19 Square Inches
    Tuning - 33 Hz
    10" W7 Enclosure Specs ($120)
    Dimensions - 33" Width x 13" Height x 15" Depth
    Volume - 1.5 Cubic Feet After All Displacements
    Port Area - 23 Square Inches
    Tuning - 33 Hz
    12" W7 Enclosure Specs ($125)
    Dimensions - 33" Width x 14.5" Height x 15" Depth
    Volume - 1.75 Cubic Feet After All Displacements
    Port Area - 29 Square Inches
    Tuning - 33 Hz
    13" W7 Enclosure Specs ($130)
    Dimensions - 33" Width x 16" Height x 16.5" Depth
    Volume - 2.375 Cubic Feet After All Displacements
    Port Area - 37 Square Inches
    Tuning - 33 Hz
    We want you to see every aspect of the enclosure as it is built. So we show photos of each stage. All of the features we talked about above can be seen in these photos. Now, go look at the competition and see if their enclosure even begins to compare in quality.
    02 WRX patrick4588's Avatar
    warner robins
    Great Price on those boxes.
    GCO Member
    NRA Member
    Hiawassee, GA
    Excellent looking boxes, top quality work, and awesome seller here. Being a builder of custom enclosures myself I can vouch for how well theirs are made. It's definitely excellent work for the money!
    -Zach-
    1987 Toyota Pickup - Toy
    Thanks!
    ........... PrOjEk_EJ's Avatar
    How long is the sale going on for ? I need one for a 13w7
    Haven't place a timeframe on it yet, just hit us up when you are ready.
    Ok I'll be back in town in July cya then
    zoom-zoom 94_cd5's Avatar
    buford
    best box hands down had my w7 box built there
    how can i buy one of those boxes from you?
    Sep 2003
    That's a solid box right there! Wishing I had something to use it for!
