Results 1 to 15 of 15
Thread: **IS a catch can a need with 300hp**
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    Default **IS a catch can a need with 300hp**
    Ive got a z6 turbo and wondering if a catch can is a need? I see people vent the vc, not sure if it makes a diff or not?
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
    Depends on how much crank case pressure you have, ring gap, boost etc...
    GWINNETT IS GREAT!
    ooh so thats what it depends on...
    Twan Jdm94Coupe's Avatar
    Fairburn
    i have a cc setup for you if you decide you want one....... pm me if interested.....
    get it, it doesnt matter what motor you have or setup.. your engine will always have blow-by; which is what a catch cans purpose is for. i look at it as a win-win situation, never have i seen a problem having a catch can vs whereas not having one blows out seals ..
    Northwest Georgia
    youll know when you need a catch can. Seals blowing out and oil leaks from valve cover and cam seals lol.
    TheMyth
    Quote Originally Posted by SPOOLIN View Post
    seen this happen before..
    you forgot the oil pan gasket too!
    Yes, without it the valve cover will literally explode, blew my boys hood off in his Cavalier.
    Northwest Georgia
    that wont happen on a honda unless the cover is compromised to start with. Cover gasket will blow out...that ive seen.
    02 WRX patrick4588's Avatar
    warner robins
    doesnt hurt to run one. go for it.
    GCO Member
    NRA Member
    Is there an EFFECTIVE way to run one without venting the vc? I don't want to weld/grind/repaint my vc if I dont have to.
    Run it to the breathers on the block.
    Northwest Georgia
    you could carefully drill and tap the valve cover instead of weld. and weld it later if you wanted. Lots of people do this with type r valve covers.
    dc5
    ATL, GA
    vent it out to the amosphere or run a line to the bottom of the car from the pcv valve..
