Thread: Trans Swap info
    IA Member DomHenry's Avatar
    Sep 2010
    Molena, GA
    Question Trans Swap info
    Hey i have a D16z6 and the transmission leaks so i had got a si trans for it alil while ago and i want to try and swap em myself.. What all tools do i need to complete this? i was plannin on puttin the car on jackstands and then drop the current trans to the ground then using a jack to bring up the other trans and bolt that good guy up..
    What size wrenches and whatnot do i need to take care of this job??
    JDM-AZ-FUK
    McDonough
    Isn't the factory D16 transmission an "Si" tranny anyways?
    Any Honda can be disassembled using 10mm, 12mm, 14mm, 17mm, 19mm, 21mm, and the axle nut which I think is a 29mm or 31mm. If you have those tools along with some wrenches and screw drivers you are good.
    Bitches love bacon.
    Sep 2010
    Molena, GA
    Ok thanks and I didnt know I was just being specific.
    So you think that process will work?
    Sent from my Vortex using Tapatalk
    JDM-AZ-FUK
    McDonough
    Trans swaps are pretty straight forward. You will need a heavy duty screw driver or axle tool to get the axles out.
    Bitches love bacon.
    Sep 2010
    Molena, GA
    How much the axle tools run?
    JDM-AZ-FUK
    Duluth, GA
    Um, axle nuts on Civics and Integras are 32 mm.
