Results 1 to 15 of 15
Thread: Y8 or ZC SOHC
    Apr 2011
    Default Y8 or ZC SOHC
    I currently have an Y7, I want to swap the Head for vtec head and Mani,
    what is better choice ZC or Y8 head?
    does anyone have a list of everything needed for the swap.
    Apr 2011
    tttt
    Macon, GA
    the zc isnt vtec... or at least the one i had wasnt, im pretty sure they didnt make a zc with vtec
    Twan Jdm94Coupe's Avatar
    Fairburn
    Why are you trying to do this? You ever going turbo or are u trying to build a n/a motor?
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    y8 have terrible oil pumps just help out
    R.I.P Booga
    M.A.P
    F.D.L.R
    Fairburn
    Quote Originally Posted by jerseyef9 View Post
    Its not the oil pumps that are the problem. The y series cranks have one hole for bearing lubrication as compared to the 2 the z6 has. If you build a y you need to set your bearing tolerances accordingly and run different weight of oil to kick your oil pressure up some. My buddy made 609whp on his y8 with the stock oil pump revving to 9500 frequently.....
    Apr 2011
    The guy I talked to said he had a Jdm vtec zc, honestly right now i haven't made my mind up on all motor or boost , right now i know i want vtec and I just want a y8 intake so the engine bay looks cleaner
    SOUTHSIDE
    Quote Originally Posted by Jdm94Coupe View Post
    thanks for the knowledge man im glad u wasnt a asshole about it
    R.I.P Booga
    M.A.P
    F.D.L.R
    Fairburn
    Quote Originally Posted by GlennsEK View Post
    i would just do a z6 head..... you can get them for good $'s.....
    you will have to buy these studs..... http://www.go-autoworks-store.com/arphestkitd11.html
    hell yea man no problem.... i mean you aren't wrong, they aren't as good as the z6 pumps still but they get the job done. modifying them wouldnt hurt either.....
    NA/Boost I got both. Supraboy87T's Avatar
    Jul 2009
    If you decide to go all motor I wouldn't use a D unless you don't care about numbers and aren't aiming for much. If I was to do it again I would have just boosted my Z6. If I'm lucky I might make 160whp when it's all said and done. I also have a lot of $$$ tied up in my setup. Back on topic if you want a VTEC head I would use a Z6 like jdm94coupe said.
    Apr 2011
    okay thanks for the help and for the manifold, does that bolt right up?
    Jul 2009
    Which manifold? I think all D's are interchangeable don't quote me on it.
    barrow county
    just dont cross obd on the manifold or you'll have to do sensor or block off conversions
    Apr 2011
    I currently have an y7, I want a y8 mani
    BB6 Prelude Srt's Avatar
    Oct 2009
    Hall County
