Results 1 to 4 of 4
Thread: Gsr hesitation issue
    PROJECTjdm project_EM1's Avatar
    Stockbridge, GA
    Default Gsr hesitation issue
    Ok needs some help I have an em1 with a gsr swap that's slightly hesitating on part throttle.
    Mods : short ram intake , walbaro 255lph pump, aem fuel pressure regulator
    Now when I first got the swap in it was running rich due to the walbaro fuel pump, so I purchased an aem fuel pressure regulator to adjust the fuel pressure down to stock spec. I also replaced the primary o2 sensor, thinking that could also be the problem. Again some what fix the issue of me burning a lot of gas, but still have a slight hesitation issue after the car has warmed up and have been driven around awhile. Also replaced the spark plugs and still no fix. I am thinking it might be a timing issue or maybe a lost of compression in one of my cylinders. Could that be the cause of it too or no.
    So can any one offer me any info or advice to what I can check next.
    Btw the motor is running on a p2t obd2 ecu, could that be a cause of the issue
    Any help is appreciated
    SoLow OutKast
    92 Civic Lx Ferio - sold
    94 Civic Dx Eg- insurance totaled
    93 Civic Si Eg6 - stolen/and striped(f**king thieves)
    00' Boosted Milano Red EM1- DD
    Dec 2008
    Northside
    When was the last time u changed the fuel filter if ever? Compression would be noticed all the time if it was that. I have seen dizzy cause a problem like this. Check rotor button and spark plug wires
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Stockbridge, GA
    I was plan on changing the fuel filter since I never changed since I bought the car. The dizzy is good check the sparks already and it all good and well
    SoLow OutKast
    Dec 2008
    Northside
    i would change the filter and see what happens, even if it doesn help maintenance is always good, a stock ecu will never make a diffrent/bigger motor run to full potential. i have always ran atleast a base map for the motor so the air/fuel ratio is close to perfect.
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
