Results 1 to 21 of 21
Thread: z6 wont rev past 3k! COME IN
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    Default z6 wont rev past 3k! COME IN
    So i have a z6 that wont rev past 3k and only cel is o2 sensor. Will a auto p28 ecu let it rev higher than that? Please reply.
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
    Dec 2008
    Northside
    If u have a 5speed then u need a 5speed ecu, I have never dealt with using the wrong ecu just thought it was common sense. Get the ecu you need, fix CEL, no need to be running around with one
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Southside Ridin HATCH
    Yea. you need the correct Ecu.
    this one seems to be in "limp" mode..
    Jun 2009
    Well, i dont have a 5speed p28 but did use a p06 and had the same issue. Changed injectors, dizzy, iat and still no luck. Changing tb soon to try new tps, maybe that will get me straightned out!
    Sig too big
    -IA Management
    =) JF868849's Avatar
    Oct 2008
    BYRON
    Yea check the tps that's probley it map sensor too I had the same probley but come to find out it was the wiring in my car where it plugs into the ecu my injector wires had been butchered and my number 2 injector wire was just chillin unplugged lol this is the built z6 right?
    h22?
    Jun 2009
    Quote Originally Posted by JF868849 View Post
    Unfortanly
    Sig too big
    -IA Management
    Oct 2008
    BYRON
    Dang see you should have traded me for the zc lol jk man but its probley that tps I would change it asap have u boosted it yet? How many miles is on it now?
    h22?
    Senior Member cm7k24's Avatar
    kennesaw
    mine did the same thing this weekend at the track,
    turned out my TPS was bad. changed it. and perfect again.
    Jun 2009
    Tps didnt work, still cutting out at 3 and bogging. No, its not boosted yet and it has like 10 miles..tops. Not sure if ill have the cash for all plans, thats why i wanted to sell but i think its something electrical, not the motor. Not sure.
    Sig too big
    -IA Management
    didn't you swap it into another car and it ran perfectly? Quit being a jewbag and put an o2 sensor on it
    My line of work
    www.internationaljets.com
    Jun 2009
    It ran good in jonathans car but never reved it. And I don't have a o2 sensor to put in it,
    Sig too big
    -IA Management
    Jun 2009
    Got all CEL's fixed and still nothing. Need ideas guys!
    Sig too big
    -IA Management
    Dec 2008
    Northside
    so you are still running a auto ecu on a 5 speed motor? you fixed 02 sensor?
    Quote Originally Posted by JDMJ View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Jun 2009
    put a 5 speed p28, still didnt change.
    Sig too big
    -IA Management
    Dec 2008
    Northside
    ok well now u have a starting point, CKP,CMP sensors in the dizzy will cause a problem like this, any ideas if the dizzy is good?
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Certified Gearhead sheasekhatch's Avatar
    Feb 2010
    around the corner
    d-series.org will be your best friend It appears the Crankshaft Position Sensor (CKP) has gone. This common on Honda distributors with higher mileage. The CKP sensor is unserviceable; therefore, you need to replace the distributor housing. I recommend that you buy a genuine Honda housing and install your old Ignition Control Module (ICM) and coil. Have the ICM tested, because the bouncing tachometer rpm readings can be indicative of a bad control module
    Dec 2008
    Northside
    i wouldnt buy anything new unless i was 100% sure that it is what i need. Distributor King makes great DIZZYs found on ebay
    Quote Originally Posted by sheasekhatch View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    I had a the same problem once, found out it was my plug wires arking. Make sure there isn't any moisture where the plugs go.
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    Jun 2009
    Swapped dizzys also, still no difference.
    Sig too big
    -IA Management
    lol ckp sensor is not unserviceable, I take that shit apart all the time and swap them out with good ones... yes its unserviceable if you're a newb...
    check
    the
    tps
    Dec 2008
    Northside
    like emino said TPS, look for a voltage change as you open and close throttle and something close to 5V at WOT, if u dont see a change thats a problem
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
