Thread: sanding and polishing rims
    Unknown
    Dec 2008
    Default sanding and polishing rims
    has anybody wet sand and polish rims beforeif so what are the steps and what do you need
    It's all about JDM.
    CA to GA
    Get rid of the paint that currently sits on your wheels with some paint remover/aircraft stripper.
    Then work with 800 up to 2000 grit sand paper with a bucket of water.
    Have patience and time, then use rubbing compound on a cloth, some more patience and time, and a nice cold bottle of beer.
    Pretty straight foward
    Certified Gearhead chompsticks's Avatar
    Apr 2010
    Athens/Kennesaw
    It's a PITA! Use lots of water. Make sure you get each grit level sanded down well for the next grit.
    :boobies:
    IA MEMBER jdm_eg8's Avatar
    When using Aircraft Stripper (don't forget latex gloves, alot, or the stripper will burn your skin)
    Apr 2009
    Villa Rica
    Stuff I used & steps I went through when I polished my gsr blades & only took me 4.5hrs (by hand, no power tools):
    100ct. Latex Gloves, (800, 1000, 1500, 2000) Grit Sand Paper, 0000 Fine Grit Steel Wool, Bucket of Soapy Water, Aircraft Stripper, Paint Brush, Metal Can (pour the stripper into it), Clean Soft Towels, Rags, ect & Mother's Aluminum Wheel Polish.
    Steps: in order from start to finish:
    -1. Use 2 pair of Ruber Gloves as stripper will eat through them quickly.
    -2. Start applying stripper & let it do what it does.
    -3. Take you fine grit steel wool & dip it in your bucket of soapy water & start cleaning the paint, clear, ect off the wheel.
    -4. Repeat step 3 if you still have paint, clear, ect still on the rim.
    -5. Once wheel is Clean from stripper, wash it down & rinse it off.
    -6. Start sanding from 800grit (wetsand) it will get really dull (I sanded in 1 direction)
    -7. Then to 1000grit & through 1500grit up to 2000grit.
    -8. If the rim is even from sanding, then apply your "wheel compound, polish, or whatever your planning on using" in a circular motion "wheel/rag will have black residue on them" & thats how you know the polish is doing what it's suppose to do.
    -9. Finally wipe off Polish or whatever your using with a clean soft towel, cloth, ect.
    -10. Your done (stand back & see the mirror effect) & have a beer!
    P.S.- if your still having second thoughts about following my steps, "GOOGLE" is your friend & you will find I followed the same process as alot of other people did.
    GOOD LUCK & BE PATIENT!!!!
    Apr 2011
    Nice write up!
    Apr 2009
    Villa Rica
    Quote Originally Posted by GlennsEK View Post
    Nice write up!
    Thanks
    Southside of The Jungle
    Pretty easy there is a better right up on HOnda-Tech! I did my fat fives couple years ago.
    Buddy Clubs Rep. I did
    Ls mesh
    All were done by Hand!
    It take time i use aircraft yhan wentto 400 grit allthe way to 2000 n alot of water
