Results 1 to 14 of 14
Thread: 97 del sol
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    Default 97 del sol
    sup guys, my friend has a 97 del sol with a d16z6, when he's driving it will stay rev'ed up to 2000rpm's. he messed with the throttle cable but that didnt fix it. help anyone?
    McDonough
    When he's driving or when it's idle? I would hope his RPMs came up as he drives.
    Bitches love bacon.
    05srt4
    Jun 2009
    nah driving, like clutch pedal pressed in. itd drop sometimes or stay up there
    McDonough
    Clutch slipping?
    Bitches love bacon.
    05srt4
    Jun 2009
    brand new clutch. it seems like his throttle is sticking. but its not.
    RIGGER Sneezin's Avatar
    redtube
    so if it always stays at 2,000rpm how does he build speed? or do he just drive slow all the time
    AccuracyPerformanceAutomotive
    Make sure he doesnt have a vacuum leak, or that the air bypass screw hasnt backed out. Did it just start doing this?
    500whp of spinnin fury!!!
    05srt4
    Jun 2009
    yea it just started when we got back from a mountain run. and for sneezin, when he gives it gas it will go up just like normal, but when he presses the clutch in the clutch disengages and the throttle stays around 2 for about 30 seconds then drops
    redtube
    ooo lol, is it throwing any codes?
    redtube
    1) remove your intake piping from the throttle body.
    2) look inside the throttle body. you will see 2 holes inside the throttle body. The top hole is for your IACV(idle air control valve). The bottom hole is for your FITV(fast idle thermal valve).
    3) with the engine running, place your finger over the IACV hole.
    If your idle corrects itself than your IACV is your problem.
    or
    4) put your finger over the FITV hole. Again, if the idle corrects itself, than the FITV is at fault. It most likely isnt broken, but probably just unthreaded itself due to vibration.
    ....i dont really know if this applies to your tb but you can try this...
    Jan 2010
    fayette
    Quote Originally Posted by Sneezin View Post
    its a single cam del sol. he will always be driving slow. hehe
    Just playin hope he can fix it.
    97 Del Sol VTEC
    05srt4
    Jun 2009
    lol it didnt fix the prob. but oh well, he'll figure it out sooner or later.
    Stang Mod slostang's Avatar
    Southside
    probably a vacuum leak or bad IACV
    05srt4
    Jun 2009
    well he has a skunk2 intake on the wrong car or something. his car is obd2 and the throttle body isnt sapposed to be on there. so his idle air control valve is on his throttle body and not on the back on the intake
