Thread: b18c1 having problem with new p72 ecu
    Default b18c1 having problem with new p72 ecu
    i just replaced my p28 with virgin p72, the car felt idle good but had no idea about vtec when i drive it just not kick in @.@ plzzzzzzzzzzz help !!!!!
    any codes? and do you have everything wired up like Knock sensor and Iab's? Does it still have the stock manifold or an aftermarket single runner one?
    My line of work
    www.internationaljets.com
    South Side Georgia
    What car is the GS-R to begin with? Did VTEC work before?
    resize pic
    Most likely it's the knock sensor as the P28 don't search for a signal for that sensor as the P72 does .
    Quote Originally Posted by Tech5 View Post
    knock sensor on OBD1 cars dont disable vtec, i had no knock with my GSR in 95 civic/unchipped p72. vtec worked.
    maybe the OP original p28 was chipped, and now with a unchipped ecu it is looking for sensors the chip eliminates
    Dec 2008
    Northside
    The info is no were near enough for people to try and help
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    was vtec working before in the p28 ecu?
    wrong
    P28 and JDM is the only ecu's that don't look for the signal
    p30 USDM and P72 USDM do so you have to have a knock sensor
    i drive slow im_hung's Avatar
    location, location
    Quote Originally Posted by *EFilliated* View Post
    ^x2...
    wrong
    nononononononono, i meant with a knock or without it should not disable vtec.
    It does if you use P30 USDM or a P72 USDM so with these two ecu's you need a Knock sensor ....If you use a p28 then it will not which is a favor ECU that most use anyways. So why run a P72 anyways?
    Also if his butterfly wire isn't hooked up that could also be a issue
    oh Josh, you are so missing the point lol
    basically what i meant was even though a p30 and p72 search for knock sensor, it does not affect vtec; from my experiences that is
