Results 1 to 40 of 51
Thread: 1996 Integra won't start
    Duluth, GA
    Default 1996 Integra won't start
    Just swapped a JDM LS into a 96 Integra. I have a ground on the tranny, valve cover, and the ECU ground on the them housing. The fuel pump primes randomly, and when it does the CeL comes on, then flashed the codes I have since I jumped the ECU.....
    Sometimes the pump primes, sometimes it doesn't. I cleaned the ground off real good and I still cant get it to prime everytime. Also, the car won't even turn over. I hear the main relay click, and the starter click, but it won't turn over.
    do you have starter wire plugged in?
    Duluth, GA
    Quote Originally Posted by NoWAyItZTOMmY View Post
    I'm not retarded. Yes I do.
    But on a lighter note, I got everything working with a few hours of elbow grease. So no more problems...so far.
    It's not about being dumb even us well educated Certified techs makes mistakes .
    Duluth, GA
    Ok, so now the car just hiccups when it cranks over but won't actually start up. The injectors are squirting and the spark plugs are firing. Anybody have any suggestions on what might be causing this.
    LAWRENCEVILLE
    gas fouled plugs will keep it from starting
    Hella stock member!
    Duluth, GA
    Yeah I just replaced the plugs 10 minutes ago, and the same thing. Car acts like it wants to start but won't actually fire.
    Greene/Athens
    timing?
    firing order is wrong
    SELL IT
    /Oo ___A___ oO\
    |=_/_______\_=|
    i drive slow im_hung's Avatar
    location, location
    is the motor obd2?
    It's all about JDM.
    CA to GA
    make sure you starter is okay. Check to see if the main power cable to you starter is secure and tight. If all is good, tap the starter housing mildly with mallet or wrench and try starting the car afterwards.
    Duluth, GA
    I haven't touched the timing since I got the motor, yes it is obd2. The only code that's up on the ecu right now is for intake air temp. And the jdm intake manifolds don't even have that sensor.
    spray carb cleaner into the tb and see try to crank it ...This will tell you if it's fuel related issue .
    J.R
    Down South
    Quote Originally Posted by Tech5 View Post
    McDonough
    I was thinking something with the dizzy also.
    Bitches love bacon.
    It's all about JDM.
    CA to GA
    Try putting the car into 2nd gear, ask a few friends to push the car down the street while you're in it, and crank the engine and give it some gas. This should start the car.
    Quote Originally Posted by gsrteg View Post
    It's all about JDM.
    CA to GA
    Duluth, GA
    I know how to push start a car, and you should only do that with a dead starter or battery. And neither my battery or starter is dead. My firing order is correct. The car kinda half started for 2 seconds or so with generous manipulation of the throttle. But didn't ever really fire.
    DID you spray carb cleaner in the tb and try to crank?
    DUDE you don't know anything please stop you're making yourself look dumb!!
    His battery and start is clearly working fine fool!
    Don't try to school me I am a ASE certified Honda/Acura Mechanic and been doing this for a LONG time !
    Duluth, GA
    Haven't had a chance to work on the car for the last couple days. I'll try out the suggestions on here and get back to ya'll tonight.
    This will eliminate the fuel system that's why I am checking ...let us know thanks!
    Duluth, GA
    Still didn't start. I'm pretty sure the compression is bad. Probly got sold a bullshit motor.
    Do a Compression check takes 2 mins
    even though you stated you did not touch the timing, i advise you to check it and correct it if it is wrong.
    Duluth, GA
    I did check it. And it's dead on the money.
    I'm doing a compression check tomorrow.
    keep us updated
    take the dizzy cap off and make sure the rotor button is secured
    :police: NeWTRouBLeArMy's Avatar
    Rome, Georgia
    ^ and check to make sure the dizzy isnt 180 out i had that problem last night and it was doing the same thing
    It's only illegal because it makes minorities act crazy and white women bump nasties with black dudes.
    He stated it's firing
    Quote Originally Posted by NeWTRouBLeArMy View Post
    if someone does this you have to be a complete retard , So if don't fit make it fit ?
    i have seen kiddos do this plenty of times, they force the dizzy on LOL
    Duluth, GA
    I did not force the distributor on. And it is sparking. I'm waiting on my friend to bring the comp tester over this evening. And I'll go from there.
    Duluth, GA
    I poured oil in the cylinders and turned the motor over a few times until the compression came up. Originally I had none. The car then started up but idled really rough. I ran the codes and got both 02s obviously, and IAT obviously. Then I had a TPS code and the CKP code. I did the ECU CKP bypass and the CKP code went away. The ECU is still in safe mode however and won't rev past 2700. The codes I have now are IAT 2 02 codes and TPS. Any ideas?
    Rome, Georgia
    no not force it on i had the dizzy apart and put the end peice on the wrong way, so if hes not using the dizzy he had someone could have had it apart and out it together wrong
    South Side Georgia
    The compression will show low if a motor has sat for over a period of time.
    check your TPS wiring for any broken connection, corrosion, peanut butter and other odd things.
    Dec 2008
    Northside
    i might of missed this but is the motor OBD2? obd2 is way more in depth when it comes to missing sensors, it will take everything u are missing such as IAT into consideration, and its POSSIBLE for it to keep u in limp mode just cuz of the IAT. get a DMM and check the TPS for a voltage close to 5 at WOT. if ur voltage does not change as u engage and disengage the throttle ur TPS is bad/REPLACE. if the voltage does change, that isnt ur problem and begin looking somewhere else
    Quote Originally Posted by Captain-Obvious™ View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
