Thread: spark issue no spark cylinder 4
    del sol? 94_teg_ls's Avatar
    Default spark issue no spark cylinder 4
    no spark just on cylinder 4 swapped dizzys with a good one and wires it like its not getting the good to go to spark help
    /sig
    WEST_SIDE
    you're not getting spark or good enough spark? and u even swapped to a known good diizzy AND wires? with the same issue?
    yes pulled it off my gsr no spark at all put the dizzy back on my running car and drove it home so its just that car
    /sig
    Stang Mod slostang's Avatar
    Southside
    main relay or ECU
    dont say ecu and we have fuel and spark every where else so its not relay
    /sig
    It's all about JDM.
    CA to GA
    Check the spark plug for the cylinder, maybe the gap clearance is not correct or the spark plug has been fouled. Oh yea, make sure your spark plug wires are in the correct sequence/locations on the dizzy. Check if your fuel injector plug for that cylinder #4 is snug and plugged. Keep us updated.
    still no start compression is good spark is good timing good fuel good swapped ecu's main relay new dizzy harness
    specs
    b16 block sleeved 84mm cp 9.1 cr pistons eagle rods
    built gsr head performer x manifold
    3 bar map 750 cc injectors was running fine 20lbs daily
    car sat for a while in the back yard let it run it was missing on cylinder 4 -no spark thats now fixed but there is no spark no spudder pop or anything
    /sig
    Certified Gearhead Thegrizz's Avatar
    Feb 2010
    Georgia?.
    i have a boosted del sol and i let it sit for a good 4 months. then cranked it. it turned out the connection on the #4 450cc dsm was bad. so pull your injectors,clean them and put them back in.they get clogged if their not run. worht a shot anyway.and change the fuel filter to help the cause. hope that helps bro.btw nice setup
    Del Slow?...
    What do you mean no spark in number 4 ? Coming out of the wire or that cylinder is skipping and you just pulled that wire off?
    If it's not getting fire from the wire but the dizzy cap and all works as you stated you put it on your car and ran fine , what about the wires?
