Results 1 to 13 of 13
Thread: Brother vs Brother
    ls2
    Anniston,Al.
    Default Brother vs Brother
    See what you guys think and what the outcome may be. The race will be next month( his motor is knocking)
    My car
    99 Ek hatch with a h22, weight reduction, velocity stack, vafc hack for a good afr, rmf style header, 3in exhaust, 125shot and some 225/50/15 bfg dr's
    his car
    92 240sx with a 1jz... mods unknown, but he claims it will be 400rwhp.. automatic
    2006 gto 6 spd intake/wr 12.8@108
    2003 Chevrolet Tahoe Lt stock dd for the wifey
    1994 Honda civic EX Sdn stock dd for me
    McDonough
    Him by any length.
    Bitches love bacon.
    ls2
    Anniston,Al.
    Run will be done at a track from a dig. He says he won't be on dr's or slicks. Just a 255 something street tire.
    SOUTHERN SPEED
    macon ga
    It should be a good race you should be making around 275 hp all motor which in a light weight hatch and good traction will be a mid 11 to high 11 second car . If he makes 400 hp his should be a mid 11 second car also. Traction will be who wins simple as . He will trap higher then you but doesnt mean he will win .
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Norcross
    i vote h22! automatic ftl
    ls2
    Anniston,Al.
    Alittle more info on his... 68mm siingle turbo, 4000 stall, 440cc injectors( i think are to small for 400whp).
    Jones hoping to be closer to 300whp.. No dyno numbers though.
    weight of the hatch is 2360lbs with driver
    weight of the 240 with driver is right at 2800lbs.
    SOUTHERN SPEED
    macon ga
    a good running stock h22 with nice bolt ons tuned makes 185 hp. with a 125shot it may be a little higher then 275 but i dont think you will hit 300 . I know a guy that had a stripped out hatch for years with a stock h22 and 75shot. He ran 12.6-12.7 pretty consistent but he wasnt h2b and had shitty gearing. i beleive you have a high 11 second car and 440 injectors is way to small for 400hp. I maxed at 440 injectors when i hit 248hp on the na h22. We had to change to 550 on the dyno just to finish tuneing lol. He has heavier car but if he makes 400hp he should still be a mid to high 11 second car also . I dont need any more info because all you can do is guess at it anyway lol. It will be who ever gets there cars to hook considering he is running street tires . neither one of you will see 11s with out slicks. Ive seen 400hp run 11.00 and in a stripped out hatch set up right 300hp na car will run a 11.00 flat also . Ive also seen a 400hp car barly make it into the 12s and a 300hp na car barely make it into the 12s so it just depends on who sets there car up better and gets traction . Not to mention lets say you run 3 tenths of a second faster then me (you 12.0 - me 12.3) if i cut a 5 tenth of a second light on you i win by 2 tenths of a second even though you had the faster time so dont forget to cut a light on him.
    ls2
    Anniston,Al.
    He doesn't have alot of exp at the track. I should be able to tree him and take him out of the hole. As soon I get rolling the nitrous is coming on.
    SOUTHERN SPEED
    macon ga
    i guess we will see.
    Certified Gearhead JDMDA_1.7's Avatar
    that 90001!
    take vid! lol
    got vtec?
    ls2
    Anniston,Al.
    Will be videod by several people!
    North Augusta, SC
    with 440 injectors, my guess is he either leans out the motor and doesn't make it down the track. or... his 68mm turbo is pointless until more fuel is able to be added.
    Back to being stock and slow
    ls2
    Anniston,Al.
    Now he has 550's and a 60 trim.
    Well, had a run last night with a friend. I thought I heated up the dr's enough. When I left on the two step I still spun, but was moving out good. Took him a full 1/4 to run me down. His best time is 13.1@106.
    I need some slicks and a h2b setup
