Results 1 to 24 of 24
Thread: Cam gears once again
    Jan 2010
    We can do business
    Default Cam gears once again
    so okay... I ordered some buddy club race spec cam gears on ebay for my buddy cluv spec iv cams... the guy writes me telling me he doesn;t have them in stock but he can replace them with a skunk2 tuner series cam gear which according to him retails for $70 more and I won't have to pay the difference. My question is the following;
    can I run skunk2 tuner series cam gears with these cams or do I need the pro series?
    Jan 2010
    We can do business
    anyone? I need to know and find nothing in research.
    i thought that cam gears where cam gears. they all mount the same way.
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    what he is trying to say is if he can use the skunk2 tuner series cam gears with his buddy club IV camshafts, or if he would need the skunk 2 pro series cam gears for his buddy club spec IV camshafts..
    Hold On Not Done Accelerating
    Jan 2010
    We can do business
    thank you all motor teg... can anyone help? the guy is waiting on my reply and IDK what to do
    Dec 2010
    down in georgia
    no problem crank, ask blk4drek he might have some info about that.
    Southside Ridin HATCH
    yes. The Skunk2 Cam gears will go with your cams
    any gears will work. be sure to properly torque the gears onto the cams because they WILL break if done wrong.
    Dec 2010
    down in georgia
    any difference performance wise between the tuner and pros??? will one of them work better with the buddy club spec IV??
    I wouldnt think soo...
    Im pretty sure they have the same amount of degrees of adjusting. They just look different.
    Maybe they have more adjusting bolts... but yea.. It will be ok.
    I have used AEM true time gears. (the Three bolt ones)
    Now I have some Skunk2 Tuner Cam gears.
    Dec 2010
    down in georgia
    what you think about the golden eagle cam gears??
    Never used them.. Shouldnt be bad. Golden Eagle is a good company.
    They guy is replacing your order with the SKunk2 tho, right?
    Dec 2010
    down in georgia
    thats what i heard and no the cam gears is for nelson and his build, i already have the golden eagle cam gears.
    Ahh.. yea thats right.
    Dec 2010
    down in georgia
    alot of people saying that the golden eagle cam gears are one of the best and that the bolts are very durable so i went that route.
    the degree on the tuner vs pro are different. tuner are 2 degree vs. pro series are 1 degree or vice verse. well in a H series case it is.
    edit:
    B
    On Pro Series cam gears (1 mark = 1° cam timing)
    On Tuner Series cam gears (1 mark = 2° cam timing)
    Dec 2010
    down in georgia
    Quote Originally Posted by NoWAyItZTOMmY View Post
    edit:
    tuner is 1 degree pro are 2
    he is talking about a b18c engine.
    Either way.... They are going to be able to adjust to what you need..
    your probly not gonna adjust them ANY more than 5 degrees
    yea, the do not seem to need much anyways, just a few degree when dialed in.
    Dec 2008
    Northside
    not trying to be a dick but i hardly dought ur build whatever that is, will need crazy degreeing if any at all, just saying. my pro1s only had 1 degree on Exh side i believe, 12:5 CTR setup.
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    TheMyth
    all the cam gears will work on their designed engine. But i doubt that they would really be used much, unless your head has been decked. Then they would allow you to get the cam timing back in place. Most of the cam manufacturers make theircams ideal at 0 degrees, but every engine likes things alil different. Some ppl gained some extra ponys with them, but on my setups i never gained anything with them.... GL with your build!!
    Three of the engines I hade, made MORE power when adjusting the cams..
    About a 5-8 hp gain..
    But like said above.. It depends on the engine..
    Also I wouldnt be adjusting the cams, unless you know the Valve clearances and ect...
    Ask for your money back and get what you wanted in the 1st place from someone else.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    Jan 2010
    We can do business
    Thank You guys. He said he could not get the pro series for me but the tuner. So I asked when he will be getting the Buddy Club ones (gold) which I originally wanted and was told it would take 2 weeks so I told him I will just wait for it since I am in no hurry since I'm still missing a few parts. Thanks for the input everyone.
