Results 1 to 13 of 13
Thread: B series oil pan question
    Marietta, GA
    Default B series oil pan question
    Can you put a gsr oil pan on an ls block? My headers don't seem to fit around my ls oil pan on my ls/vtec setup but they fit on my gsr block when it was in the car. All help is appreciated with reps. Thanks
    all motor power...
    If anything the gsr oil pan is bigger than the Ls one by about 1/2"
    My line of work
    www.internationaljets.com
    Marietta, GA
    I can't explain it then. I have an ls/vtec on an engine stand and I had a full gsr in the car with the headers on it. When I pulled the swap out I test fit the headers on my ls/vtec and they hit the oil pan.
    all motor power...
    Marietta, GA
    the headers are smsp 4-2-1 that have been welded together.
    all motor power...
    it could be due to the height of the combination of LS bottom and Vtec head. i dont know for a fact, but i do know that a LS is taller than a B16. the same concept could apply to your current combination
    Marietta, GA
    did not know that... hmmm. this might be tricky.
    all motor power...
    Southside Ridin HATCH
    O thought LS and GSR blocks are same height. Hmm....
    ^^^Yep, that would make sense because the cranks and rods can be moved from one block to another.
    My line of work
    Quote Originally Posted by Starrfire View Post
    With a few modifications that is... But yea.
    Marietta, GA
    So I tightened up the headers completely and it looks like it might just be the positioning of the headers when they were welded. They clear the pan on the top, but they are really close to the tall side of the oil pan, not quite touching, but almost ball hair clearance.
    all motor power...
    RIGGER Sneezin's Avatar
    redtube
    lmao ball hair clearance,,,thats a first,,but good
    Marietta, GA
    ^^^thank you, i'm here all week...
    all motor power...
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    thats enough clearance! i know i modified a b16 one because the b16 block is about an 1/8 to 1/4 inch shorter and it was still a tight fit and is still runnin strong! hell thats how hondas roll with super tight clearances right i mean id rather have it a little tight than to wide! thats women n cars lol.
