Results 1 to 32 of 32
Thread: My D15B8 is burning oil but not smoking, not sure why please help!!!
    Oct 2009
    Warner Robins, GA
    Default My D15B8 is burning oil but not smoking, not sure why please help!!!
    I have a 94 coupe DD with a D15B8 engine in it. It only has 150k miles on it and it burns oil like crazy. It doesnt smoke at all, it runs strong, it drops about 2 oz of oil every 3,000 miles (between oil changes) but I have to add about a quart of oil every 1,000 miles or so. Where is this oil going?
    leaking
    325is NJSC's Avatar
    Dec 2009
    Buford
    Check the driveway. If it's not smoking then it's not burning.
    that's how I roll
    Oct 2009
    Warner Robins, GA
    not leaking, i drop maybe 2oz between oil changes. I know im burning it. And you can burn oil without it smoking.
    check your coolant for chocolate
    it's all in the motor that's where it's going
    thats where oil is regardless
    barrow county
    if your burning oil, YOU'LL SEE IT. especially that much oil.
    Stang Mod slostang's Avatar
    Southside
    What you are experiencing is the "Angel's share," common problem with older hondas. Usually as you are describing, around every 1,000 miles or so an Angel swoops into your oil pan while youre sleeping and uses 1qt of oil to lubricate its wings. If you search for a fix to the issue, it will make the angels very angry and will bring you very bad karma. Id suggest leaving it alone.
    But in all seriousness its probably your valve stem seals.
    Dahlonega
    are we making irish whiskey, or are we talking oil consumption with the Angel's Share... lol
    valve stem seals are my guess as well. likely smokes for a second or 2 on start up, then stops. burns it while driving down the road, and can cause little/no smoke...
    Southside
    Quote Originally Posted by Cynical 1 View Post
    I was wondering if anyone around here would know what i was talking about. lulz
    barrow county
    It's magic oil. Now you see it, now you dont
    325is NJSC's Avatar
    Dec 2009
    Buford
    So it does in fact then smoke?
    that's how I roll
    GWINNETT IS GREAT!
    bro my lude burns and leaks so much oil..
    i put half a quart to a quart evrry 300 miles
    my motor always has fresh oil!!
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    damn....
    Oct 2009
    Warner Robins, GA
    Thanks for the help, between you and slostang, its apparant that you two are the only people on this thread that want to actually help someone with there problem rather than post stupid usless crap to make there posts number go up. I hate punk kids.
    Oct 2009
    Warner Robins, GA
    could it also be piston rings as well as the valve stem seals? This is my son's dd and he says he babies it but you know how that goes with 16 year olds.
    could be piston rings, in the morning when the engine is cold.. stand behind it and let someone crank the car up. bad valve seals will cause alot of blue smoke to appear upon startup
    Oct 2009
    Warner Robins, GA
    I think its the valve seals. I know your not supposed to reuse head gaskets but the one I have on it is only a couple months old and im really not trying to pull the head again and spend another $60 on another head gasket. Would that one be ok to use again if when I pull the head it stays in tack? Im assuming that I have to pull the head to change the valve seals
    reusing a old headgasket is a failure within a failure, slap yourself Lolol. if you pull the head, have it checked for warpage and get a NEW gasket from autozone.. you will thank yourself in the long run
    Southside
    Could possibly be rings, not not very likely. Valve stem seals are WAY more common of an issue vs ring issues.
    Simple way to test rings, do a compression test when the engine is bone cold. The readings should be atleast 150psi.
    Oct 2009
    Warner Robins, GA
    I know I know just kills me to shell out another $60 got a head gasket when I just did but ill suck it up. When I pulled it last time I checked for warpage and it was flat so I will pull it again and change the valve seals and check to make sure the valve guides abd valves are still straight
    Southside
    What weight oil are you running?
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by slostang View Post
    5w20
    Oct 2009
    Warner Robins, GA
    So I have a haynes manual but it doesnt say how to perform a compression test or leak down test. Could someone PM me and walk me through it or send me a link? Im mechanically inclined! lol also, cold or warm?
    Southside
    Step your oil up to a 15w40 rotella. It should take care of most of it.
    As for a compression test, go to auto zone and rent a compression tester. remove all 4 spark plugs and screw the testers tube in spark plug hole and spin the car over for atleast 5 seconds. repeat that process for all 4 cylinders and youll have results.
    Oct 2009
    Warner Robins, GA
    I got the compression test set, do i need to do the test with a warm or cold engine?
    Southside
    Quote Originally Posted by r.etheridge View Post
    Sorry i forgot that. Cold. Or both if you feel spunky.
    Id be almost willing to bet it not your rings though.
    Dahlonega
    you do NOT need to pull the head to do valve seals.
    simply remove the valvecover, cams.
    get an ohc valve spring compressor (under $100 at auto parts stores, cheaper at harbor freight).
    also buy a (forget what it's "technical" name is) adapter that connects to an air line, and screws into a spark plug hole. this will pressurize the cylinder, hold the valve in the head, and allow you to change out the seals.
    google what i am talking about for pics and such - on car valve seal job or something along that line...
    Oct 2009
    Warner Robins, GA
    I think a leak down test kit will pressurize the cylinder and I have one if so. Cool, so I think it while I have all this stuff apart, I will change out the valve guides as well and I suspect that it can be done without pulling the head as well?
    Dahlonega
    you can't replace valve guides without pulling the head. they are pressed in and out. plus, the valve is in them, and will fall into the engine if you manage to get a guide out while doing this...
    just do the valve stem seals.
    Oct 2009
    Warner Robins, GA
    so my compression was starting with the cylinder on the driverside and the last # being the far left on the pass. side 150-160-130-160. all are in spec 184psi max 135 min. but not withing 28psi from the highest # to the lowest. What do i do next?
