Originally Posted by
Cynical 1
you do NOT need to pull the head to do valve seals.
simply remove the valvecover, cams.
get an ohc valve spring compressor (under $100 at auto parts stores, cheaper at harbor freight).
also buy a (forget what it's "technical" name is) adapter that connects to an air line, and screws into a spark plug hole. this will pressurize the cylinder, hold the valve in the head, and allow you to change out the seals.
google what i am talking about for pics and such - on car valve seal job or something along that line...
