Results 1 to 10 of 10
Thread: tach or dizzy prob?
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    Default tach or dizzy prob?
    my tach on my 92 eg hatch at a certain rpm will go all crazy. like at 3000rpms it will shoot to 7 and then just go wack-o. what causes this??
    Certified Gearhead DA9_Vito's Avatar
    Dec 2009
    Forsyth,GA
    the cable is bad. or you speed sensor is bad.
    replace cluster see if it fixes problem, if not replace ignition coil. do either in whatever order you want
    Dec 2009
    Forsyth,GA
    wouldnt you start with cheap and easiest first? like cables and sensors.
    Quote Originally Posted by smart_ion View Post
    Quote Originally Posted by vitodon1 View Post
    he drives a 92 civic, it does not use any type of cable for its tachometer, and i did specify the exact sensor which may be bad
    again there is no cable and has nothing to do with speed sensor
    then again, im not a mechanic
    Dec 2009
    Forsyth,GA
    oh damn for some reason i was thinkin 92 was still cable. my bad.
    its all good, were here to help the OP not to dispute over grammatic errors
    Dec 2009
    Forsyth,GA
    lol im use to mine so hydro is beyond me.
    Southside Ridin HATCH
    YUP
    05srt4
    Jun 2009
    Pickin up an msd external coil from t2ku to see if that works. Cuz I had the same prob I'm my ef and it was the coil
