Thread: Check engine light problem
    1989 honda civic dx 4wslude's Avatar
    at a jack in a box
    Default Check engine light problem
    I have a 95 dx and the check engine light came on last night and then car shut off I got it back started and the check engine light stayed on and I go to check the code and the light goes of for a second and then comes back on and stays on like it has no codes or is it showing code zero should I try another ecu or what the car doesn't drive any different I wa just going down the I interstate around 70 and then it just shut off and then when I try to start it it just spun over so I waited a little and then it started and drove fine what could it be the day befor the car was acting up and showed code 43 the car was bogging and flooding out and popping realy bad when giving it gas driving not when revving up standing still
    my ef does that too but since i replaced a 255 warboro fuel pump, fuel filter, fuel regulator, and a set of f22 injector it runs a little better but still have the same problem so i gave up on it, for me i'm thinking it might be the resistor box because i have a obd1 d16z6 in it and the wires from the resistor box was not wire to where ever i need it to wire to get rid of my resistor box.... every time it bogs on me ALL I DO IS REV IT UP AND GO LOL.....
    92 Hatch redneckhatch's Avatar
    White Castle
    You wish you had a 95 Dx but your stuck with your little ef maybe we will figure both of our problems soon.
    J.R
    Down South
    Quote Originally Posted by jdmalltheway View Post
    probably the 02 sensor
    McDonough
    By chance, you check your timing belt?
    Bitches love bacon.
    J.R
    Down South
    as for the 95 dx if you have never changed your fuel filter this could be your problem, or your o2 sensor (code 43 is fuel system supply) sometimes the o2 is a tad bit dameged and reading off and the ecu doesnt always pick it up right away if at all
    at a jack in a box
    Ok I'm going to try a filter and check and be sure non of the wires are melted or anything on the o2 I think it's the thing right under the throttle body with the 2 screws on it my other honda did it and I messed with that and it fixed it it still has the factory fuel pump in it also I might change it
    Quote Originally Posted by redneckhatch View Post
    not into coupe so that y i got me a ef hatch
    Quote Originally Posted by NOCLUE View Post
    that my next step
