Thread: suspension once again... DESPERATE
    Jan 2010
    We can do business
    Default suspension once again... DESPERATE
    okay now I am frustrated. I have KYB agx in the front and just bought some used Koni yellows(adjustable) that I just installed in the rear... I have ground control coilovers... I tested the shock and it was good before I bought it I pushed it down and it came back up with no problem...
    After I installed them, I noticed the car is like 4x4 NO BS it is super high in the back and the sleeve is adjusted to be all the way down. I can stick 3 fingers between the quarter panel and tires and the car is also SUPER SUPER bouncy. IDK what to do. does anyone know what this can be?
    Earth
    Uhhhh... Are the springs seated in the cups? I'm drawing blanks here...
    Scottish Scotsman's Avatar
    on the road to recovery
    did you take off the dust covers?
    You have the spring perch on the koni yellow at its highest, remove the spring perch and put the retaining ring on the lowest groove
    Dahlonega
    did you try ANYTHING we suggested in your other thread first?
    Jan 2010
    We can do business
    the adjuster is under them but yes
    Quote Originally Posted by Scotsman View Post
    are you talking about a sleeve looks like a black round thing that goes over the strut?? if so I didn't
    spring perch? can you explain this please
    Quote Originally Posted by Cynical 1 View Post
    I decided to keep it since it was not bouncy just not perfect riding.
    Jan 2010
    We can do business
    fixed the problem thanks guys.
