Results 1 to 11 of 11
Thread: fresh b series build = blown head gasket????
    VTEC Killa!! 99' LuDe's Avatar
    Warner Robins,GA
    Default fresh b series build = blown head gasket????
    ive been building my motor over the past month eagle rods wisceo pistons bearings you name it, cranked the car up tonight and let it run for 30 mins ran fine no problems at all but when i went to change the oil it was obvious i blew the head gasket. head was torqued to arp sepcs and i never had a problem before. im open to any ideas to what caused this cause at this point i wanna sell the bitch for parts...
    1999 bb6 rip 1998 dc2 sold 2003 ep3 totaled 1999 em1 ftw
    NITROUS JUNKIE
    home
    what kinda b series? lsvtec?
    YR88 Win! Romeo's Avatar
    Middle Ga.
    ^My question also. I've had it several times where people use the wrong headbolts/studs. ARP makes head studs specifically for the ls/vtec or b20/vtec setups.
    you installed it wrong, it cant be anything else.
    Warner Robins,GA
    its a b16a block with a b16 head
    either you installed it wrong, or the head/block deck is warped
    Middle Ga.
    Yeah, true. Very easy to put it on upside down.
    Southside Ridin HATCH
    Yup.. pop that head off.. and make sure.
    Senior Member WalkS's Avatar
    Middle Ga
    Did it over heat when you let it run for 30min? You could possibly have a crack in the head, just throwing an idea out there. But can't really say anything specifically since the head isn't off.
    JJSPEC Racing
    Middle Ga.
    And if its cracked, its definitely warped... Lol.
    Feb 2010
    Zebulon
    agreed. a local machine shop can vacuum test the head for cracks, and tell you if it needs to be milled
