Thread: 99 accord cluster lights.
    Senior Member EJdm's Avatar
    Default 99 accord cluster lights.
    Every now n then the battery light n brake light will turn on n off when ever it wants to while driving. Wat could this be? It's a new battery.
    "Arriving at one goal is the starting point to another." – John Dewey
    SOUTHSIDE
    alternater belt is loose -- that will fix the battery light
    add brake fluid your running low -- that will fix the brake light
    or your alternator is going bad
    Fluid is good imma have to see about the belt though..thanks
    SOUTHSIDE
    check the wires on the brake fluid cap... or the wire on the hand brake
    Scottish Scotsman's Avatar
    on the road to recovery
    Quote Originally Posted by wrekonize View Post
    i second all this man has said
    Super Handling
    For the brake light: It's the piece of foam inside the reservoir. When it's cold, it won't float as well causing the sensor to think brake fluid is low. Most likely cause.
