Thread: i need to know can i use Ls piston and rods in a B16 bottom end
    Default i need to know can i use Ls piston and rods in a B16 bottom end
    just as title says i need to know if i can use Ls pistons and rods i a B16 bottom end? i have a b16 block everything complete minus the pistons and rods. if not is there any other type of piston an rod combo that i can go with?
    McDonough
    Two different bore sizes. Do proper machining and you should be able to.
    Bitches love bacon.
    BK ALL DAY
    bore size is the, the stroke is the difference...
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    aye bro .:Stirfry:.'s Avatar
    nope wont work, yea bore is the same stroke is totally different.
    ATL DAsquad Member #9
    McDonough
    My bad. I was thinking B18 to B20. Those are different bore sizes.
    Bitches love bacon.
    Sep 2009
    wont work....stroke difference....also u cant use ls rods on a b16 crank
    NYC 2 ATL SPEED CO.
    "STRETCH BUILT"
    Morris tuned
