Thread: suspension... KYB AGX and Ground Control coilovers
    Jan 2010
    We can do business
    Default suspension... KYB AGX and Ground Control coilovers
    okay guys as many of you know I have KYB agx shocks and had some ebay cut coilovers and my car was pretty low... NOw I installed some some Ground COntrol COilovers and it is super comfortable. I'm havign a problem with this though. The back of my car can go really low... The front driver can also go really low but my passenger front is barely tucking and it does not go any lower. I am frustrated. Has anyone had this problem and what was it?
    i used to own KYB AGX and OTS ground control coilovers, i had this same exact problem. after switching around springs, modifying the top hats and forks, i figured it was because of the design of the spring. not much you can do about it, and please do not cut the spring trying to get lower
    Jan 2010
    We can do business
    lol so pretty much my ONLY option is raising the rest of the car?
    yeah, or get koni shocks so you can put the spring perch lower
    Jan 2010
    We can do business
    im done spending money on suspension lol... im just gonna raise the whole car the way the passenger front is and enjoy my clearance and good camber something i havent been able to before... and comfort for the first time.
    Certified Gearhead jfryer496's Avatar
    Feb 2010
    Phenix City, alabama
    ur dc is fuckin sickk lol spend more money on sups
    Feb 2010
    Zebulon
    make sure that the coil over sleeve is installed in the proper place. others have often installed the front on the rear, this will cause a similar problem to what you are having.
    The Slums of GA
    kybs suck. you mind as well drop a couple more hundred on something worth more and worth keeping like konis
