Results 1 to 18 of 18
Thread: Engine coolant froze!!!
    South Side Georgia
    Default Engine coolant froze!!!
    Well, Sunday night i was too lazy to drain the water and pour antifreeze. I wake up Monday afternoon and first thing i do is to check if the coolant (water) froze before i even cranks it. I open the radiator cap and its completely frozen. All coolant hose there is to the engine are rock hard. I managed to melt the radiator, but the block if didn't want to mess with because i don't want to risk damaging the water pump, or worse, cranking the block.
    Thing has never happened to me, but those are the consequences for me being lazy.
    Since I don't have a garage, what are some methods that could possibly help without causing any damage? Should I wait until the water melts? Thanks in advance
    resize pic
    Projects
    Ive been told that if you fill it with coolant as much as you can and let it sit fir a while that coolant will melt the ice.
    South Side Georgia
    I was told the same, but the coolant would only get as far as the radiator top and lower hoses end. They are frozen entirely till both water the block and head water necks.
    resize pic
    Projects
    Quote Originally Posted by gerardojdm View Post
    hmm all i can think of is if dont have one find a friend with a garage trailer it there an use it and a few space heaters over night.
    LAWRENCEVILLE
    DO NOT TRY TO START IT! If you have a small space heater or a very hot shop light put that under the front of the engine give it some time to warm up then drain the water out and fill with coolant. make sure you get the block good and warm before you try to start it
    Hella stock member!
    Southside Ridin HATCH
    Damn bro is your car still at bobs... Has it been frozen for two days now?
    Take the hoses off if need be, let them "thaw". put them back on, fill the Rad with Antifreese..Some how heat the block too. You should be good dogg..
    F.O.C.U.S jdmshytyo87's Avatar
    Oct 2009
    cedar bluff, al
    bet you wont be lazy anymore lol, GL,,,,,
    Quote Originally Posted by jdmshytyo87 View Post
    I had this happen once for the same reason (lazy, to cold) and I learned my lesson.
    South Side Georgia
    Quote Originally Posted by X-Runner View Post
    yea, it was 24 degrees outside and I was tired from work.
    resize pic
    LOL, sucka. light a BBQ grill next to your car.. and wait, seriously
    South Side Georgia
    Water pump cranked
    resize pic
    Projects
    Today would have been a perfect day for it to melt all the way it was pretty warm out lol
    Senior Member EJdm's Avatar
    Wow...I learn something today.
    "Arriving at one goal is the starting point to another." – John Dewey
    Earth
    Quote Originally Posted by EJdm View Post
    *learned
    Now you learned two things.
    McDonough
    /tweet.
    Let's fill with antifreeze now.
    Bitches love bacon.
    SOUTHSIDE
    nice going cherrios....
    pour gas on the engine and light a match...
    problem solved.......
    Privateer Racing!!
    Duluth,Ga
    I did the same thing too my car. Only thing it did was over heat when i tried too drive it.Im hoping i didnt pop the headgasket. I know the water pump is fine. I think the heater core just stayed frozen everything else is thawed out...I HOPE!!! Or maybe my theromstat is stuck closed
    GWINNETT IS GREAT!
    thread is full of lulz
