Results 1 to 11 of 11
Thread: b16a2 questions?
    beware of the HB's bullet67's Avatar
    cartersville
    Default b16a2 questions?
    So, I've purchased a b16a2 it came with the original harness and a p2t ecu. My questions are what exact wiring harness and ecu I need to put this into a originally non vtec honda del sol. I have the S version of the del sol so that I have all the bases covered. Also if anyone is in the market I have a CRV harness and of course a 2000 civic si harness and ecu to get rid of.
    thanks,
    What year del sol?
    My line of work
    www.internationaljets.com
    cartersville
    use the original harness and add in pins to the ecu and into the existing harness or just route them with the harness.
    www.phearable.net
    My line of work
    cartersville
    The only issue I have with that is the original harness has the ecu plugs attached to it how do I go about using the original harness
    Quote Originally Posted by bullet67 View Post
    you cant.
    cartersville
    Well see that's what I thought so what harness and ecu do I need to make this work?
    use your original engine harness and chip your p28, its the cheapest and probably the best way to do it
    cartersville
    So you're saying I can use my non vtec del sol d series harness?
    ^^^Yes, you only need to run a few wires. You live in Cartersville right, which is an hour away from me. i could technically help you since I have all the pinouts and factory pins. Its an easy procedure since you have extra harnesses.
    My line of work
    cartersville
    ok, good deal. it will just be a a little while before i can afford the other parts i need to actually get it set up but its good to know i can use my harness fairly easily. I'll let you know when i've got it all together and ready. thanks for the help.
