Results 1 to 15 of 15
Thread: Here we go again b20vtec big issue
    Champ
    Feb 2010
    Warner Robins GA
    Default Here we go again b20vtec big issue
    B20bgsr head was running fine. I work from 930 pm to 830 am left work yesterday morning drove for about 10 seconds it bogged then shut off and wont start remember it was 30 degrees. Im getting fuel and spark 1 and 2 compression went from 0 to 25 and immediately back to 0 . Someone figure this out. I've heard head gasket but idk why it wont start. No antifreeze in the oil b20vtec in 2 weeks old just built.
    Southside Ridin HATCH
    If you aint got compression, Thats why it aint starting.
    As far as WHY it lost compression.. hm.. RINGS, GASKET... That pretty much sums it up
    Champ
    Feb 2010
    Warner Robins GA
    Alright someone figure this out hahahahah timin was perfect. Spent 15 minutes getting it perfect. When I was running threw the steps you know spark, gas, air. Well had all that and assumed timing was on because I felt the belt and it was tight. Well towed it home and took vc off to find this
    http://i1034.photobucket.com/albums/a426/b20b_vtec/2010-12-08_04-34-03_17.jpg[/IMG]
    PROJECTjdm project_EM1's Avatar
    Stockbridge, GA
    Fixed pic for you
    SoLow OutKast
    92 Civic Lx Ferio - sold
    94 Civic Dx Eg- insurance totaled
    93 Civic Si Eg6 - stolen/and striped(f**king thieves)
    00' Boosted Milano Red EM1- DD
    nice you checked the timing alright. Sure it doesn't have bent valves now?
    My line of work
    www.internationaljets.com
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    check your tensioner you jumped timing but it doesnt look too bad
    Oct 2008
    Quote Originally Posted by Starrfire View Post
    thats what I was thinking about the valves but it doesnt look too badly off IMO
    Champ
    Feb 2010
    Warner Robins GA
    Valves are fine drove it to work. Timing was perfect when I put the motor together. I've never seen a car jump 5 teeth in timing. I didn't check it because valve cover was on when I got it home I check and this was it but when I was looking at it in the Parkin lot at work the timin belt was tight. Idk I drove to work today beat on it alittle bit and runs perfect. How do you know if your tensioner is bad? It was tight as well. I just redid timing and that's it. I figured I should have got a new tensioner but I had to drive to work.
    your belt stretched for a split second.. thats all, too much maD tyte vTec
    Tensioner might not have been tight or wasn't tensioned right when the belt was initially installed.
    My line of work
    when you took the valve cover off did your cam rail bolts come off with it?
    ^ hah.. I see that..hmm
    J.R
    Down South
    ^hahhaahhah i saw that to
    Champ
    Feb 2010
    Warner Robins GA
    Ha-ha naw was about to swap head gaskets.
    center field
    if your dizzy is going bad it will make it jump timeing too, had the same thing happen , check your dizzy make sure it turns freely and dont bind or wana sieze up
