Thread: overheating in other prob?
    Rome,Ga
    Question overheating in other prob?
    97 civic ex d16y8
    ive replace thermostat ,radiator ,all hoses head gasket torque everything back down still over heating my heat works what could it be? i have to keep puttin water in the radiator like every 2 days was puttin antifreeze did the same ?
    next prob the car has poor start off in motor seems to be runnin sluggish
    i am thinking the knock sensor on this one? i had my codes ran in said malfuntion on cylinder 1 knock sensor.
    have another code it say fuel/air metering?
    also on the d16y8 i cannot figure out where this fuel/emission hose goes
    less than a foot long?
    Projects
    Have you bleed the air from the coolant system before driving it ?
    Rome,Ga
    no how do i do it?
    Projects
    Quote Originally Posted by terrytowe22 View Post
    no how do i do it?
    With the radiator full and cap on get the car warmed up then on the Thermostat housing you will see a Screw thats like a valve.
    Open it a little till you see air bubble coming out and once they stop and its just clear water close it.
    Hondas have to have the air bleed out of the system or they will run hot.
    J.R
    Down South
    Ya bleed it, and did you do a compression test be for you replaced the head gasket
    Rome,Ga
    no compression test but some days the motor will run really strong,
    Certified Gearhead deondre's Avatar
    Jun 2010
    did bleeding the system fix your prob?
    WTB 16x7 Polished Slips
    Rome,Ga
    i couldny find the bleeder screw
    locust grove
    the upper radiator hose, follow it to the cylinder head, that waterneck has a 12mm bleeder valve, just like a brake bleeder valve just 12mm not 10mm
