Results 1 to 10 of 10
Thread: f22a with a h23a non vtec head?
    Certified Gearhead cprtyler's Avatar
    cedar town
    Default f22a with a h23a non vtec head?
    i have read that this is possible and i have also heard that its the same as a f22b dohc in the end result. the reason im asking is that my f22a head is damaged real bad and i have a good h23 head iv heard that its simple if someone would or could help please do, i dont need no negitive feed back like go vtec or go full h23 i have spare parts laying around and there good just tryin to go with what i had
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Del sol w/h22 all motor
    Del sol w/ls swap sold
    Dc2 Itr ft w/B20v dd
    the intake and exhaust side are the same, the cams are the same. the oil return to the block is different, but some how it works. if you can get your hands on the f22b dohc head you will be easier install. sohc heads are easy to find. i have a few and you can find them at pull a part.
    About to approach beast mode
    www.jjspec.com Macon, Ga
    You will need a competent aluminum welder and machine shop to get it right. We have done a few so we could get the head ready for you. Just dont know what your budget is. PM me if you are interested.
    cedar town
    Quote Originally Posted by JJSPEC Racing View Post
    i thought that was on the vtec head only, from what i have read (and it took me along time to find it) was that there was one oil passage that only that had to be blocked off on the non vtec head? and that it was basically bolt on
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Still similar to the Vtec head. If you dont fix it you will have an oil leak and waste a head gasket. I have seen it before.
    dont you have to weld up the oil return around the water jacket on the head???
    Pretty much. There are actually about 6 spots that need to be welded some(not fully covered) to do the job correctly.
    my friend and i were looking at a sohc and a dohc block in his basement and we wondering how people were doing the h head on sohc blocks.
    cedar town
    is it worth it at all power wise
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    The vtec version helps out pretty good.
