Thread: type r swap
    vtak yo! E.G. KING's Avatar
    Austell, GA
    Default type r swap
    decided to keep my ej and do a type r swap what do i need other than the engine tranny and ecu? can i use stock mounts? and i noticed on vteckidds thread that if i did a type r swap that the 36mm axle to 32mm hub problem occurs how do i avoid that? just need a few answers
    CP
    aye bro .:Stirfry:.'s Avatar
    http://www.honda-tech.com/showthread.php?p=19728360.
    done. just use stock dc mounts
    and dc axles
    ATL DAsquad Member #9
    Austell, GA
    cool thanks bro and the shift linkage aint different between a ls/gsr/type r right?
    CP
    ls and gsr shift linkage are identical but the type R one is slightly different in the bends but one of the three will work perfectly fine. IMO if you have the R one use that one.
    Austell, GA
    got ya
    CP
    Southside Ridin HATCH
    If it aint a Type R, then it aint a Tight car!
    Same as a gsr swap minus the need for IAB's.
    My line of work
    www.internationaljets.com
