Results 1 to 4 of 4
Thread: how to wire up my dizzy?
    Greene/Athens
    Default how to wire up my dizzy?
    Alright guys I'm swapping a d16a6 (obd0) into my 95 civic as a temporary fix until I get finished rebuilding my d16z6. I read somewhere that I can modify my obd1 dizzy and get it to fit but I also read I could just wire the obd0 up to work and I would much rather do that.
    Thanks for any help
    aye bro .:Stirfry:.'s Avatar
    all you have to do, to use the obd0 dizzy is cut off the plugs off both dizzys and wire the new pig tail frm the obd1 dizzy onto the obd0 dizzy all the wires are the same.
    ATL DAsquad Member #9
    just use all d15b7 stuff on the engine. Like use the thermostat housing and temp sensor off the d15/d16z you have and treat the a6 like a d15. Ignore that it is a obd0 engine by putting all obd1 stuff on it. Also use the d15b7 dizzy since the head is the same cast.
    My line of work
    www.internationaljets.com
    Greene/Athens
    Quote Originally Posted by Starrfire View Post
    Cool I didn't know that the d15 dizzy was a direct fit. I've already swapped out the thermostat housing. One more question though, I don't have a motor mount for the a6 (old was was broken) so I bolted on the one from my z6 and noticed it was made a little different. Is this gonna throw the motor out of proper alignment? should I get a d15 mount or another a6? Thanks again guys
