Thread: Help car makes click noise
    9 rpm
    Default Help car makes click noise
    got an 01 integra gsr when i reverse it make a couple click noise and the same as going forward. the noise is coming from the area around the fender. my two guess are the gear or the wheel bearing. but if anybody ever have that issue lmk thanks.
    Projects
    usually the bearing or CV joint
    McDonough
    Axle
    Bitches love bacon.
    9 rpm
    so you guys think it not the tranmission.....
    McDonough
    Start simple and work your way down the list. Check your axle boots for rips or anything of the sort. Usually, an axle will make sounds in reverse or in turns or any kind of movement really.
    Bitches love bacon.
    9 rpm
    just looked at the axle boots they are in good shape not rip or damage. im guessing it the wheels bearing but i could be wrong.
    Projects
    Quote Originally Posted by tuyen View Post
    jack the car up and see if the wheel has any play in it if it does then its the bearings
    Jun 2009
    Mine did that and it was the bearings. Check em by doing what enVus said ^
    Dahlonega
    my guess is the brake pad sliding around in the caliper.
    honda had a tsb about this 10 or so years ago on the elements.
    brake pad has too much clearance side to side in the caliper due to a faulty clip, and clicks in forward and reverse as the pad moves about in the caliper. same should apply to any vehicle that has a similar clearance issue...
    deal with it, or replace the anti rattle clips and brake pads was honda's fix... may want to have a look at your brakes...
