Results 1 to 14 of 14
Thread: integra bogging out
    WTB Disco Potato SOHC1's Avatar
    Default integra bogging out
    whats up guys. well my car started bogging out 2 days after i bought it from this dude. so we checked the timming and it was off by a little. we fixed it and didnt really solve the problem but got kind of worse. swapped sparkplugs and still the same. so now after each cold start it boggs like crazy under 4k rpms. i have to let the car sit for like 5+ minutes so it can bogg less. but if i shut it off and turn it on again it starts to bogg for like the frist 5 minutes of drivig. i dont know where to start. so if some one could please help me.
    barrow county
    sounds like you need to take it back
    first check for cel codes and go from there on
    Hwy 315
    it boggs down when... under throttle? at idle? when too many fat people sit in it?
    details - we need them.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Quote Originally Posted by jdmalltheway View Post
    i dont have any dude..
    yea it bogs under little throttle under 4k. as long as i slam on the gas it will pull...also when im on the road u can feel the car lose power at times. like im doing 4k u can see the idle drop to like 3900 than pop back up at 4
    Norcross
    clogged cat? moisture in dizzy?
    sound like my ef right now except mines is doing it at 3k rpm and it's worse than yours...i recomend using a fuel pressure gauge to check your pressure if it's in spec
    JDM TYTE AnthonyF's Avatar
    How many teeth was the belt off? Do a compression test to check the cylinders. Move to the distributor next and see how it is.
    -Ant.
    The Carbon Fibered R6
    It was off by a little. Can't remember how much. I bought the alternator cap and rotor see how that goes tomorrow. Ill keep y'all updated. Thanx guys!
    Quote Originally Posted by j0nbunklah0m View Post
    I'm runing a straight pipe. I bought a cap and distributor cap and rotor. Ill keep y'all updated. Thanx man!
    WEST_SIDE
    it really sounds like a bad MAP or horrendous vacuum leak. it realy sounds liek you have more then one issue tbh.
    but i doubt the plugs will solve it.
    Quote Originally Posted by SLow_POke View Post
    i guess i have to start somewhere...lol like iv been getting different things from people and from what iv searched..
    well the problems been fixed. ither was the distributor cap,rotor or the wires, i replaced all of them at the same time so i dont know what was the problem. lol thanks guys. yall been reped
