Results 1 to 11 of 11
Thread: car just wont die
    del sol? 94_teg_ls's Avatar
    Default car just wont die
    well i have had this civic for a few weeks and all the sudden today it wont cut off turn the key down still running driving me crazy so i need to know where to start
    so far i disconnected the dizzy to cut it off
    if i disconnect the battery all dash lights stay off but as soon as i turn the key up then back down it does it again also the switch still is working if i have the fan on with the key all the way up it blows turn the key down it turns off but the car still runs
    help?
    /sig
    also if i turn the key up then back down batt light is still on but if i unplug the main relay then plug it back up lights stay off i think there is a relay sticking but its not the main relay
    /sig
    could be the ignition switch
    My line of work
    www.internationaljets.com
    Quote Originally Posted by Starrfire View Post
    +1 thats what It sounds like to me
    /Oo ___A___ oO\
    |=_/_______\_=|
    checked and good im not sure where its coming from but the main relay is keeping a very small amount of power enough to keep the relay stuck if i manually pull the magnet and what ever the piece of metal is apart inside the relay with the key down it wont pull it back so im going to pull the multi meter out and see how many volts it is keeping in there anyone have a pin out for the relay
    /sig
    Smyrna
    Why not pull the fuel pump fuse? That will kill it.
    98 EJ8 - Stolen ( Thieves)
    its my girls dd cant have that but its fixed now thanks
    /sig
    NITROUS JUNKIE
    home
    my car did the same exact thing..it was the main relay on mines
    GWINNETT IS GREAT!
    starter
    SOUTHSIDE
    THE WHITE PIECE THAT BOLTS UP TO THE BACK OF THE IGNITION
    REPLACE IT AND THAT SHOULD DO IT
    its already fixed it there was 2.47 volts holding the relay open
    /sig
