Results 1 to 10 of 10
Thread: build d series, and a jrsc kit..
    about this far.
    Default build d series, and a jrsc kit..
    i'm looking to start something new, i was thinking a build z6 and little head work, but my question was. with that set up is it better to run a low compression bottom end or is it better to run a high compression end, also what cam should be use, turbo or n/a?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    about 10.5-11:1 is what I'd run on a supercharged setup.
    My line of work
    www.internationaljets.com
    about this far.
    Quote Originally Posted by Starrfire View Post
    how much boost?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    ^^ Most ive seen were 6-9 psi.
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
    Boostin, yo!
    Oct 2008
    covington
    i would also run a bisi cam, maybe the 2.4
    BK ALL DAY
    indeed
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    center field
    ha what up tree this is damon i got some rods and pistions low compression.........and i have done the sohc sc befor pretty fun but only good for a dd .
    Northwest Georgia
    12:1 and some E85 on that bitch and ROLL OUT!!
    on a 100 degree day it will be hell but all other times you should be fine with 93 fuel.
    known as Charles
    I would run a little higher comp then stock if you are going to build it. But for JRSC I would just run the stock motor with some headstuds. That SC can't move enough air to need as built motor. Also, remember the more power you make with the motor the less extra power you will make with the SC added, if that makes sence.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Northwest Georgia
    yes it makes plenty cents.
